CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
CL Weight Saving
Old May 21, 2014 | 07:23 AM
Alex L's Avatar
CLK56TT (WIP), S65, RR 5.0 S/C
CL Weight Saving
Didn't know where to post this to be honest but maybe we can share some ideas on how to shave some unnecessary weight of our CLs.
Apart from forged lightweight wheels I've also had rotors custom made for my 55k. Results are below. The weight is in kilos.
Front OEM @ 36.18 lbs:
Floating front custom @ 26.94 lbs:
Rear OEM @ 21.01 lbs:
Fixed rear custom @ 16.42 lbs:
Had them made to OE dimensions, hence 2 new OE discs in the pictures.
Old May 21, 2014 | 10:01 AM
kamilclk430's Avatar
W215 V12TT Build by Speedriven, W221 S550 4Matic
That is exactly what these cars need is a good diet. Rotating mass is def the way to go. So far I bought Recaro seats that weigh in at 20lbs with brackets vs our OEM 70+lbs seats each. Rear spare along with tools saves a bit also.
Pic of my seats
Old May 21, 2014 | 10:42 AM
V12Godspeed's Avatar
Your worst nightmare...
That's a good start. Stock rotors are extremely heavy!
Old May 21, 2014 | 11:22 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
I'm banking on completely removing ABC being a sizable reduction once it's all said and done
Old May 21, 2014 | 12:37 PM
Mercedes22's Avatar
S500 LWB ( W221 ) - CL63 Biturbo ( W216 ) CL 55 Kompressor ( W215 Sold ) C43 AMG ( W202 Sold )
Cant wait to see your CL Alex ( C43AMG MBClub ) Peter
Old May 21, 2014 | 04:48 PM
dfwx's Avatar
W215 CL65
Who did the rotors and how much?
I wish there was more info available about the chassis/body structure. Also curious of the type of sound deadener used in terms of weight and any structure that may exist only for crash testing and not integrity. I would guess the glass moonroof and motor is a few pounds.
Old May 21, 2014 | 06:17 PM
Welwynnick's Avatar
2006 S600
They sure are. Each front rotor is 50% heavier than the whole w215 front subframe!
Nick
Old May 22, 2014 | 09:32 AM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
My rotors look the same and I also had custom aluminum hats made a few years back for them. Sure saves a lot of weight.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
