CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
::ECS Tuning:: Mercedes-Benz CL63 Pipercross Performance Air Filter Set
Old Sep 16, 2014 | 03:42 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
Click HERE to order or for more information.
Only - $98.86*
Your CL63 is a masterpiece of engineering that pumps out power with incredible fuel efficiency. Sophisticated as it is, however, it still needs thousands of gallons of air to burn a single gallon of fuel.
Don't settle for stock. Pick Pipercross filters, designed with a progressive foam filter media that promotes air flows, without compromising filtration efficiency.
Track tested for the last quarter century, Pipercross Performance Filters are durable, cleanable, and tough enough to protect your engine for years and thousands of miles.
*Price subject to change.
Old Sep 16, 2014 | 06:04 PM
Welwynnick's Avatar
2006 S600
Engines are expensive. How does the dust filtration efficiency compare with paper filters?
Old Sep 17, 2014 | 11:27 AM
ECSTuning's Avatar
2012 SLS AMG
Welwynnick,
Pipercross air filters are engineered with dirt retention capabilities far beyond that of a conventional air filter, and due to their unique, proprietary foam compound, they can hold up to twice the amount of dirt of a standard air filter without the same loss of airflow.
A Pipercross air filter will allow a 30% increase in airflow over a stock paper element air filter, and with this increase in airflow will come an increase in power output.
This is a washable, re-usable lifetime air filter, and Pipercross will honor the warranty so long as Pipercross genuine cleaning products were used on the air filter.
Click HERE for the Pipercross air filter cleaning products
Series 5 is an industrial division of Pipercross' parent company, Filtration Control Limited. The filters are produced in the same way (multi-layer foam density) so the data applies. You can get to comparison tests by clicking HERE, also the lab report can be found HERE which includes an ISO 5011 pressure drop test.
I hope this information helps in your decision on a Pipercross Performance Air Filter. If you have any further questions, please do not hesitate to post or send a PM!
Old Sep 17, 2014 | 02:28 PM
Welwynnick's Avatar
2006 S600
I appreciate the response, but I don't think that answers the question; I was asking about filtration efficiency, not dirt retention.
In other words - how much (fine) dust does the filter let through, compared to paper?
Nick
Old Sep 17, 2014 | 04:15 PM
ECSTuning's Avatar
2012 SLS AMG
Nick
Nick,
I apologize for the misunderstanding on my part. I am attaching the dust feed test that our contact at Pipercross has provided us with. Unfortunately this does not show a side by side comparison to a paper filter, and still does not fully answer your exact question. I have, however, reached out to to our contact at Pipercross to find out all that I can to answer your question. I will update as soon as I have more information.
If there is anything else I can do for you, please let me know.
David
File Type: doc
