V12TT exhaust mod question
My biggest concern is, will it sound stock in idling/cruising 70mph on the free way? Last thing I want is to ruin the luxury this car provides but I would to hear a little noise when I get on the loud pedal
Thanks in advance!
sounds amazing.
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Would you suggest keeping the muffler incase I want to weld it back to go stock? Not sure how feasible this would be after putting straight pipes.
On my car the previous owner had some exhaust work done and a muffler shop put a small section of crush bent 2.5" pipe ahead of the mufflers. I planned to cut that out to remove the restriction, but once I fired it up with no mufflers I went ahead and built Y-pipes and deleted the mufflers completely while reusing the stock tips.
I've seen vids with res del but none is showing how loud/quiet (or if there's a drone effect) is inside the cabin when cruising on highways at, say, 80-90mph (european highway cruising speed, abt 130-140km/h).
Deleting mufflers is not an option here, sound restrictions are enforced...
1) muffler delete only
2) resonator delete only
3) resonator and muffler delete
Not sure which route to go? I want it to sound stock as possible at idling/cruising highway but when I get on the loud pedal I want to hear the women/children scream LOL
Deleting the mufflers makes the exhaust audible, but not at all loud in the car, is emissions legal, cheap, does not require tuning, mil eliminators, or any other mod to compensate for it. It is a sound mod only, not a performance mod, but not loud enugh to make anyone scream in terror.
Deleting cats may add power and throttle response, but it is more expensive, will throw a CEL without a tune &/or MIL eliminators, is not emissions legal, makes your exhaust smell like an old car, & may cause an anoying drone on the highway.
Deleting both = LOUD
