CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Rear View Mirror Memory Setting Problem
Old Nov 17, 2015 | 11:33 AM
khutchinson22's Avatar
CL55
My passenger side rear view mirror is constantly losing it's memory settings. Some days it's fine while others it adjusts on it's own to a new position and has to be re-programmed. Is this an issue with the mirror motor or some other component?
Old Dec 18, 2015 | 10:54 AM
pamiboy's Avatar
E 350
Are you the only one driving the car? Do you use both keys at different times?
Old Dec 18, 2015 | 10:56 AM
CL55
I am the only one that drives it and there is only one key.
Old Dec 18, 2015 | 11:01 AM
pamiboy's Avatar
E 350
If still under warranty I would call dealer. I believe you can also try a software reset. Anyone has any other suggestions?
Old Dec 25, 2015 | 01:57 AM
CL55
It's definitely not under warranty. Software reset?
Old Dec 25, 2015 | 05:18 AM
Television's Avatar
CL500 216
My 216 can do this, I have to go back to D and then back to R to get it to dip, not easy to know where the fault is.
Old Dec 25, 2015 | 08:55 PM
CL55
It's not that it's not turning down/in. It will do that most of the time. The issue is that some times when I push up OR in it will slowly go up AND in and the opposite is also true. I just want to know if its the motor causing this or something else before I start spending money.
Old Jan 13, 2016 | 07:53 PM
CL55
Anyone? Bueller?
Old Jan 14, 2016 | 11:27 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Here's a possibility...
https://mbworld.org/forums/e-class-w...tion-only.html
Old Jan 14, 2016 | 12:06 PM
CL55
Originally Posted by bbirdwell
Thank you! I will give this a look.
