CL55 AMG, CL65 AMG, CL63 AMG (C215, C216) 2000 - 2014 (Two Generations)
Front License Plate
Old May 23, 2016 | 03:36 PM
cliffsmarsh's Avatar
2005 CL65
Front License Plate
I am now residing in a state that requires two plates.....ugh! Anyone have recommendations on a front bracket without drilling holes in my CL65?
Can zip ties do the trick?
Old May 23, 2016 | 08:30 PM
AllenOU's Avatar
2014 E350 sport
In the same boat in Texas. Ugh. What a dumb law. I'm NOT drilling into my bumper lol
Old May 23, 2016 | 08:40 PM
desired_speeds's Avatar
2007 SL55 AMG
My mom's c class came with an undrilled bumper and I did not want to touch it so I used a strip of 3m exterior mounting tape and stuck the plate on. It holds well and the plate will be mangled before you could pull it off.
Old May 24, 2016 | 07:10 PM
RoadHazard's Avatar
Speedriven CL600 V12TT
Rho plate V2 works perfectly - it's a tow hook plate mount. I just run front plate-less because I hate the look but it's the least invasive option.
http://www.rhoplate.com/v2.html
Old May 24, 2016 | 11:00 PM
Ridgeback's Avatar
Ordered AMG GLE 63 S Coupe
Best solution found
Skene Design have a sleek bracket system for front license plates w/o any visible holes
Old May 25, 2016 | 04:42 PM
2005 CL65
Skene does not have a solution for CL Class.
Old May 26, 2016 | 10:12 AM
xabo's Avatar
'20 S63
Here in D.C. I only get tickets from parking enforcement. I glued two black earth magnets to the inside of the lower grille and two to the back of the plate. Now when I park, I slap the plate on and remove it when I leave.
Depending on what you're willing to spend the top two may be an potion:http://www.amazon.com/s/?ie=UTF8&key...l_6xubem2dhz_b
Old May 28, 2016 | 02:12 PM
Blkvip's Avatar
12' E559
just get a retractable and mount it to the under panel
Old Jul 15, 2016 | 12:21 AM
Streetsoffire's Avatar
W216 CL65, W219 CLS55
Those show-n-go plate mounting options suck......they don't last under speed (I had one on my AUDI Avant, blew right off from the turbulence).......is there a tow hook option for the W216?
Old Jul 15, 2016 | 08:04 AM
StarvingArtist's Avatar
CLS 55 AMG E500 ML320
I used the factory bracket, with double stick tape and a couple dabs of silicone.
