CL55 amg axle ratio change
It would be amazing to have a CL with a 3.50 R&P! I'd just be afraid of snapping axle shafts if you could get the car to hook in first gear.
i know guys replaced their Ratio's from (2.65 to 3.06 or 3.27), will losing top speed, but amazing Results,,
just be sure; to go with big pumpkin to handle the 55k power..
"ZAYED"
I remember hearing people using a TCU from a car that came with those gears, but others having issues. Glad to hear it's working for our platform, share any info you can get.
Nick
R230 Sl55 is the only M113K family, which has a higher Ratio (3.06>>2.82),
E55/Cls/Sl55 uses the same diff., but the difference with Ratio only,
*if i'm not mistaken; W215/W220 got a differ diff., don't think it can be swappable with "E/Cls/Sl",,
unless if changing the Ring & pinion only for Ratio desired..!???!
-;ZAYED;-
"Cl & S" 99% sharing the same equipment,
i think "R230 Sl55" Ring & Pinion can be swapped into "W215/W220 Cl/S55", but can't assure that..!,,
anyone here got any info. about that, pls. chime in..
-;ZAYED;-
This is not the same rear as the AMGs and 600s, despite being the same platform. Take a look at pics on line, your see the difference in the front mounting to the rear support, the 3 prongs instead of 4 bolting for the driveshaft flex disc. I think the breather vent is in a different location as well. I'm guessing the internals are not as beefy on the 500s.
