lowering my clk
Old Mar 4, 2005 | 10:04 PM
skiffnvancity's Avatar
lowering my clk
hey guys
i want to lower my clk, and improve the ride. i know you can just get new coilovers, but what are my other options?
cheers
Old Mar 4, 2005 | 10:28 PM
CLK430ROB's Avatar
hmm.
No such thing as coilovers for our cars. Its either a spring / shock setup or air ride. Not many choices.
Rob
Old Mar 4, 2005 | 10:44 PM
King320's Avatar
03 C32 AMG
Koni makes a good set of shocks and for springs you have eibach, H&R, Kleeman, Renntech, and a few others. Most pople like H&R because they perform well for the money.
Old Mar 4, 2005 | 11:46 PM
brianw430's Avatar
'03 G500, '11 S550 4Matic, '12 SL63 AMG, '13 ML350, '16 AMG GTS Ed. 1
I may have a used set of Carlsson springs/dampers for sale. I got them from Evosport and from what I gather will not fit a CLK55. If that is indeed true, I will probably take them off. It loweres the car very nicely, not slammed, and the handling is greatly improved.
Old Mar 4, 2005 | 11:47 PM
how mcuh
how much? and is it everythign i need to lower the car? i.e. i don't need any new supports or anything like that
Old Mar 5, 2005 | 01:23 AM
King320's Avatar
03 C32 AMG
You're looking at about $210 for Konis and about $230 for H&R springs Plus install. All done it should be about $550.
Old Mar 5, 2005 | 12:11 PM
ViKTORiOUS's Avatar
W209 - W163
H&R Cup Kit is the way to go
Old Mar 7, 2005 | 10:01 AM
lz_clk's Avatar
1999 CLK 320
Originally Posted by skiffnvancity
hey guys
cheers
No such thing. Lowering the car will only degrade the ride, unless you are going for a harsh, tight ride, which some people are....
Old Mar 7, 2005 | 12:16 PM
Josh K's Avatar
Tesla Model S
Not completely true. My car is lowered and sits on Koni adjustables. On the softest setting the ride is indistinguishable from stock. I wanted better handling so I turned the stiffness up a notch.
The thing that did change ride quality a bit was the 19" wheels.
Old Mar 8, 2005 | 02:07 AM
CLKBSVegas's Avatar
a Black
And mine is for sale. But, "improves the ride"...that is personal taste.
Old Mar 8, 2005 | 03:36 PM
clkal's Avatar
01' CLK55
after you change out the shocks and springs, make sure you do not forget about changing out the SPRING PADS, if you want to go even lower!!!!!!!!
Old May 17, 2007 | 11:06 AM
oneofayykind's Avatar
01 CLK 320 Cabriolet
I was told that if I get 19" rims my car has to be modified? Is this true? What modifications would I need to do for 19" rims? I was told I can get 18" without modification but 19" requires some sort of speed sensor to be altered or other modifications? I really have no idea so I guess I'm just wondering if I buy 19" rims what I need to do besides get some H & R springs to lower it a little.
Old May 17, 2007 | 12:41 PM
deyainrdy4ds's Avatar
w208
Rob
KW makes coilovers for our cars...
Old May 17, 2007 | 04:20 PM
SETSEROCK's Avatar
HPF E46 M3 Turbo, LET C32 AMG
are spring pads a nessecity? or are they just for extra lowering?
Old May 17, 2007 | 05:21 PM
CLK FAN's Avatar
2000 CLK 3.2
Highly doubt it. They might make a shock and spring but not a coilover. You would have to completely reconstruct and customize your factory suspension. If you can show me someone who has it or some pics or even a link to what you have seen maybe I'll believe it.
