W208 with Shift boot
Old Mar 23, 2005 | 04:54 PM
dennism13's Avatar
CLK 320
Question W208 with Shift boot
I did a search on shift boot under the clk55 and w208 forums and could not find somebody who has tried. Anybody tried and willing to post pics? www.amgkit.com has something for a w208, but made for manual transmission.
thanks, -D
Old Mar 23, 2005 | 05:07 PM
GrantWinTX's Avatar
CLK 430
You can't seriously think about buying anything from AMGKIT.com when their prices are even more than the dealer for most stuff!!
Old Mar 23, 2005 | 05:12 PM
dennism13's Avatar
CLK 320
Was not considering buying from them . Just an example of what i found. Wondering if it looked like a shift boot fit the interior style of a w208.
Old Mar 23, 2005 | 06:20 PM
King320's Avatar
03 C32 AMG
Go figure, thats perhaps the best parts supplier i've seen to date and it's also the most expensive.
Old Mar 23, 2005 | 07:28 PM
CLK430ROB's Avatar
Ask mmgrad
Danny (mmgrad) did that to his CLK. He put a benz shiftboot/knob on his 430 auto. Looks pretty good. Post some pics Danny... u pic *****.
Rob
Old Mar 23, 2005 | 07:52 PM
dennism13's Avatar
CLK 320
I checked out the other MB forum and they mentioned MMGRAD had done it. If the inside looks as clean as the outside I'd want to check it out.
MMGRAD, how 'bout a pic?
Old Mar 23, 2005 | 08:03 PM
dennism13's Avatar
CLK 320
MMGRAD you have mail
PM'd ya.
Old Mar 24, 2005 | 01:00 AM
mmgrad's Avatar
W213 '17 E43 ///AMG - W211, W208 no more
yea, i have a shift boot on my w208 clk...
here's a before pic...
here's an after pic...
it looks better in person... but, the boot is not a direct fit, you need to do a little handywork...
Old Sep 6, 2009 | 12:31 PM
gn3's Avatar
gn3
CLK430 Cab 03
mmgrad,
Any chance you can repost a photo. I'm interested in trying this? Where did you get the part? What's involved?
Old Sep 6, 2009 | 02:56 PM
deyainrdy4ds's Avatar
w208
Originally Posted by gn3
mmgrad,
dono if u realized or not but this thread is 4 yrs old.....
Old Sep 6, 2009 | 10:40 PM
gn3's Avatar
gn3
CLK430 Cab 03
Oops, well if anyone has a shift boot, let me know.
Old Sep 6, 2009 | 11:53 PM
dlbehrns's Avatar
99CLK320,
I made a boot out of black garment leather so it was pliable when moving the lever for and aft, had a friend sew it. cut four triangular pieces, figure in the offset of the shift lever to the right. pry the rectangular piece from the console, use Barge contact cement to glue the leather boot to the underside of the rectangular piece and press everything back in place. worked for me.
Old Sep 7, 2009 | 11:28 AM
gn3's Avatar
gn3
CLK430 Cab 03
So is your winter switch inside the boot?
Old Sep 8, 2009 | 11:04 AM
mskochen's Avatar
clk
I installed a momo knob and boot in a similar fashion - removed the plastic surround and worked the boot into the crevice. The tight fit keeps it in place with no problems. The sport/winter switch is hidden underneath the boot, but that's not a problem since I rarely use it.
Got it from this place: http://www.ltbmotorsports.com/
I went with the short (6") boot and plain knob - fits perfect. I'll try to take a pic this afternoon.
matt
Old Sep 8, 2009 | 11:06 AM
mskochen's Avatar
clk
matt
02 clk 430 convertible
Old Sep 9, 2009 | 02:34 PM
gn3's Avatar
gn3
CLK430 Cab 03
Nice setup, I may do the same. Did you put the plastic ring back on or no? Let see a pic.
Old Sep 10, 2009 | 11:33 AM
mskochen's Avatar
clk
I did not put the plastic cover back on - because of the thickness of the leather, it would not fit. But with the overhang of the boot, and the fact the wood trim that was under the ring cleaned up nicely, I don't think its too noticable. The best part is that it can be easily returned to stock if need be.
I've actually been asked a number of times if its a stick, instead of automatic, due to the look (even though there is obviously not a clutch pedal?!?)......
Here's some pics, I hope they help.
Matt
Attached Thumbnails W208 with Shift boot-inside-1.jpg   W208 with Shift boot-shifter-3.jpg   W208 with Shift boot-shifter-1.jpg   W208 with Shift boot-shifter-4.jpg
Old Sep 11, 2009 | 11:48 PM
dlbehrns's Avatar
99CLK320,
Yes. Mine is hidden as well but as the other gentleman said, I never use mine either. I have a bit less leather on mine.
Old Sep 13, 2009 | 03:44 PM
clk430convert01's Avatar
2002 CLK55 AMG cabriolet
dlbehrns ... which boot did you install?
