Searched, but no real info on changing the door speakers
Old Oct 4, 2006 | 10:10 PM
The Jury's Avatar
2002 c240
Wish I had pics, but even a good diy tutorial would do. Nothing really informative came up in search.
99 clk 430
Old Oct 5, 2006 | 01:27 PM
deuxslow's Avatar
W215
What do you need help with? I just removed my driver door panel yesterday, which people always seem to have a fear of doing it seems. If you have questions about the actuall install I may be able to help.
Old Oct 5, 2006 | 04:18 PM
The Jury's Avatar
2002 c240
just wanna know the basics on the removal before i do it.
Old Oct 5, 2006 | 04:55 PM
deuxslow's Avatar
W215
Oh cool then. All you'll need is a phillips screw driver, flat head screw driver and anything made of thin ridged plastic. I try and post pics of how to remove the door panel.
Pry the inner door handle off (big one used to close the door from inside). Remove screw behind it.
Use a flat head screw driver. Stick between the top gap where the arm rest is and gently twist.
The little SRS cap needs to be removed. Remove screw behind it
I used a small flat head screw driver. gently pry off the cap.
Almost done.
The little chrome plate on the door has three little screws. remove those only. The chrome plate does not need to come off.
Use something made of small rigid platic and slide on the under side of the door panel. Gently pry the door panel apart every couple inches.
Once all the clips are out*. Lift up and away and the door panel should come right off. *Left and Right verticle edges of the door panel and bottom edge.
Two wires to disconnect.
1. A wire clip from behind the panel to seat control buttoms. Unclip that.
2 On the very bottom of the door panel is a little tiny light. It has to little wires connect to it. Unclip those two little wires.
BTW make sure the window is down. Simply swing the door panel up so that it rests on the window seal.
The speakers use phillips screws. Remove those and the rest I'm sure you can fugure out. It should take about 5 minutes to remove the panel.
Old Oct 5, 2006 | 05:37 PM
The Jury's Avatar
2002 c240
nice, thanks!
what size is in there?
Old Oct 6, 2006 | 12:55 PM
deuxslow's Avatar
W215
I want to say for the 5.25in for the front and 3in for the little back one.
The big speaker is mounted to a sealed box. The little one is free standing.
Old Oct 6, 2006 | 08:16 PM
Spining's Avatar
MB CLK 200 kompressor cabrio w208
u're talking about this?
[IMG][/IMG]
Old Oct 7, 2006 | 02:06 AM
clk22's Avatar
2003 clk55
6.5" front of the door and 4" rear part of the door
Old Oct 7, 2006 | 04:51 PM
deuxslow's Avatar
W215
Sorry about the measurements, I just glanced at them.
Old Oct 8, 2006 | 01:09 AM
The Jury's Avatar
2002 c240
Oh that would be GREAT. I pulled my comp system out of my IS300 when I sold it and I have Focal 6.5 components for the front stage.
I spent too much on that and I'd love to reuse it all. I was just worried about the front being 5 1/4 because they sounded so terrible.
I have a Mcintosh double din (was never sold in stores) for a head unit, focal components, MB Quart DVC ten's, Audio Control EQT's, Audio Control crossovers, PPI ART amps, and a fwe other goodies I'd like to stick in the Benzo. It was a top shelf SQ system so it'll fit well with the Benz theme.
Old Oct 8, 2006 | 10:28 PM
bnz.'s Avatar
02CLK320
It is long way to go, my friend, but much worth it!
https://mbworld.org/forums/clk-class-w208/157482-finished-new-system.html
By the way, there is a good review currently on eBay about Denon Z1 (same as mine) head unit
http://cgi.ebay.com/ws/eBayISAPI.dll...m=230034585513
Old Oct 8, 2006 | 10:53 PM
The Jury's Avatar
2002 c240
https://mbworld.org/forums/showthread.php?t=157482
very nice stuff and great install, but I am disappointed to see kicker as your low end after buying all the top shelf stuff you bought. There is so much more out there for low end SQ.
Still, lot's of money in that and very nice.
Old Oct 10, 2006 | 04:30 PM
bnz.'s Avatar
02CLK320
I assure you it is only because you have never heard old-school Kicker.
Old-school Kicker is much different from nowadays Kicker and first of all because in the recent years Kicker itself was sold to somewhere in Korea or alike but used to be Kicker amps were 100% US made (their old motto - "America's Music Machines") and made very well.
Kicker ZR1000 amplifier was Kicker's top of the line, best amplifier with a list price over $1200, which is quite not cheap, if you agree, for any two-channel amp.
But most important, this amp is simply ))) THUNDER ((( - honestly. Ears can't handle its full volume if you seat in a car. And quality is great too. After all, don't forget its only work is to produce low frequencies from 25 to 80 Hz.
But anyway, check out the reviews here:
http://www.carreview.com/cat/car-aud...8_1806crx.aspx
Finally, about my Kicker C15VR subwoofers. Of course there are more expensive subwoofers around but will they sound any better? Not necessary. In most cases, the only difference between $200- and $2000-subwoofer is the power that it can handle but again these C15VRs can handle much more than I. And their sound quality is , believe me.
Old Oct 10, 2006 | 08:07 PM
The Jury's Avatar
2002 c240
I assure you I owned 3 car audio stores and was MECP certified as far back as 1993
Too bad we never did any 208's. I wouldn't have even needed to ask the original question.
You're biasing yourself towards kicker because you had them from your old car. Finish that system off with some Focal's or something
Doesn't mean I don't like it, but no one can kid themselves about ANY kicker product against the big top 5.
Old Oct 11, 2006 | 02:31 AM
bnz.'s Avatar
02CLK320
I have ... MB Quart DVC ten's
Old Oct 11, 2006 | 07:08 AM
The Jury's Avatar
2002 c240
MB Quart DVC ten's
A.K.A.- JBL T-104 reference (circa 1992) loudspeaker WOOFER.
