Xenon H7
Old Oct 26, 2006 | 07:42 PM
zdfun's Avatar
2005 CLK 500 Coupe
Smile Xenon H7
Hi all,
I am a new owner of a 2002 CLK 320. I would like to change the headlights, and saw people are selling Xenon H7 bulbs on ebay. Is it ok if I just change the light bulbs? Will it hurt or damage the car? Any suggestion? Thank you.
Zdfun
Old Oct 26, 2006 | 09:09 PM
ThrillKill's Avatar
CLK/ML
Those are not really xenon gas capsules, just a name. I would be careful as they tend to get super hot. I melted a harness once.
Old Oct 28, 2006 | 05:11 PM
JamesYang's Avatar
00' CLK320
I just change my original light bulb to xenon H7 yesterday, it's really white in color, but i found that it's not bright enough, it looks pretty good when it's really dark but when there are street light around, it's not bright enough.
But I am satified with it.
Hope this would help you..
Old Oct 30, 2006 | 09:04 PM
Motivation's Avatar
CLK 430 Coupe
I couldn't agree more, be careful !! I too have melted wiring harnesses, but multiple of them.
Old Oct 30, 2006 | 09:54 PM
bbearden's Avatar
'03 E55 (My Daily), '01 ML 320 (Wifey), Twin Turbo '69 Camaro (In Progess)
Aside from the dealership, where is a good place to get the Xenon capsule replacement bulbs? Price?
Old Oct 31, 2006 | 10:15 AM
JamesYang's Avatar
00' CLK320
Just got a question..
Can our car use this..??
it says 100W
and how do you guys think..?? is this one any good..??
http://cgi.ebay.com/XENON-6000K-SUPE...QQcmdZViewItem
Old Oct 31, 2006 | 12:15 PM
raymond g-'s Avatar
99 E320
your car is spec-ed for about 60 watts on the high beam...plus a little for
insurance. you plug in a 100 watt bulb, nearly doubled. chances are you
will encounter the wiring overheating mentioned earlier. if you were to even
attempt this, i would strongly suggest you fabricate a supplemental wiring
harness, isolated by a relay. fuse the downstream harness as well. so if
it is going to blow, it'll trip the fuse....and/or protect the expensive factory
harness in the process.
Old Oct 31, 2006 | 04:39 PM
JamesYang's Avatar
00' CLK320
thx for your reply, I will wait till i recieve the item first..but kind of afraid to try it on..
the reason why I order this bulb is cuz ..first it's cheap and second the visibility of my current lightbulb isn't enough although the color is good..
thx for your suggestion..!
Old Oct 31, 2006 | 04:47 PM
zdfun's Avatar
2005 CLK 500 Coupe
If only the bulbs will burn out, then I just change it, but I do concern about the wiring and the connector may have problem too. The bulbs are under $10, but may cause you $100+, so maybe looking for those 55W white light bulbs is better. Thank you everyone.
Old Oct 31, 2006 | 05:01 PM
zdfun's Avatar
2005 CLK 500 Coupe
The one you bought is 100W, I think you should get a 55W. According to the user manual, the original bulbs from manufacture are 55W. It sounds a lot better than plugging in those 100W bulbs.
This one is 55W H7 Xenon light.
http://cgi.ebay.com/ebaymotors/ULTRA...46751923QQrdZ1
6000K is the color temp., is it just the brightness of this bulb? Do we need to worry about this number?
Old Oct 31, 2006 | 06:16 PM
JamesYang's Avatar
00' CLK320
Thx for helping!!..I think I would order this one..
Old Nov 3, 2006 | 09:27 AM
Whodat's Avatar
2000 CLK 430 Cabriolet
There's a thread on this topic somewhere. You'll have to search for it but somebody here went thru the trouble of posting pictures of bulbs with various ratings. The 'K' in 6000K is for kelvin. I believe they give off different colors as the rate goes up but I can't be sure. You'll have to ask somebody (try ThrillKill) for more detail.
Old Nov 3, 2006 | 10:58 AM
ANGEL1's Avatar
don't waste you time and $$$ with those ebay xenon bulbs
because many of them are just junks
they blow out after a few months unless you get the top name brand bulbs like piaa or raybrigs.......but then you will have to pay a lot for them
Go with HID kits.......looks way better
make sure you get the philip hid kits and not one of those MADE IN CHINA stuffs..........good luck
Old Nov 3, 2006 | 04:18 PM
zdfun's Avatar
2005 CLK 500 Coupe
Thnaks for your info, can you recommand some websites so I can take a look ? I am thinking not to get those cheap bulbs too. Thanks a lot.
Old Nov 8, 2006 | 10:38 AM
ANGEL1's Avatar
why waste money?
You brought a nice ride...............a Benz
you should not go cheapo with parts like headlight bulbs......
Most of the aftermarket xenon bulbs on ebays are from Asia and they do not last very long.........except for the name brands like Piaa and raybrigs
Just pay a little more for a HID kit and no overheating issue and much brighter light
