Brake Booster Hose & Check Valve
Old Dec 27, 2006 | 02:29 PM
ToneDog614's Avatar
2000 CLK430 Cabriolet
I need to replace the brake booster check valve, but the replacement part comes as an assembly with the entire vacuum hose. Does anyone know how to remove the brake booster vacuum hose from the intake manifold? The hose will not release by just pulling on it, and the manifold end is not easy to reach or even see for that matter. Thanks in advance.
Old Apr 10, 2010 | 02:46 PM
jose.angeles's Avatar
CLK 430 2002 C240 2002
Brake Booster Hose - Manifold
Did you ever get a response to this. My vacuum hose going into the bottom of the intake manifold as to be replaced.
Do you have to replace the entire manifold or can you replace just the hose.
thanks
Old Apr 10, 2010 | 10:00 PM
2PRECISE's Avatar
clk55 amg
to reaslse the hose, you need to push in two tabs then pull the hose out.
Old Apr 10, 2010 | 11:55 PM
Intake Manifold vacuum line
Not sure If I was clear, the part I am having problems with is on the bottom of the manifold - there are no tabls there.
Old Apr 11, 2010 | 09:17 AM
2PRECISE's Avatar
clk55 amg
take a pic so i can see it. I just replace mine, not sure if its the same.
Old Apr 11, 2010 | 09:30 AM
Manifold vacuume line - see attached drawing.
Also see these links....
I think this company sells a replacement.
http://www.brinsonco.com/store/product107.html
http://www.brinsonco.com/store/page8.html
New question - are there special tools required to remove teh manifold - i.e. all the other hoses/lines coming in?
Is there anything special I need to be carefull about?
thanks.
Attached Thumbnails Brake Booster Hose & Check Valve-manifold-vacuum-hose.jpg
Old Apr 12, 2010 | 01:29 AM
MarcusF's Avatar
2002 CLK430
Any dealer can sell you that part. It's part number 0002760030 and has a dealer list of $15. Just looking at it, I don't see why the intake would have to be removed.
Old May 7, 2014 | 08:12 PM
sirswift93's Avatar
CLK320 Cabrio 2001
Did the Brinsonco part ever work for you?
thanks.
I am in the same predicament as you. I looked at the Brinsonco part and ordered it but i'm not sure it will work. Someone else told me that it will not allow the vacuum to build up in the chamber for reserve purposes. I found another company in Asia that sells a vacuum line with a barb on the end to seal it off. See below.
I have already purchased the new gaskets and MB sealant to replace the intake manifold after the repair. Does anyone know the torque requirements for the eight bolts?
Thank you!
Old May 8, 2014 | 04:44 PM
jonUF02's Avatar
2015 GL550 4matic
Everything I have seen shows that this part is not replaceable. It is a stupid point of failure for the entire manifold. See my thread about removal and cleaning of the manifold. I don't see how that part will attach or work. Maybe by drilling out the original fitting and then tapping a new fitting into the metal???
The second hose with barb might work, basically you are putting a splice connector into the piece of the hose that is stuck in the manifold. I would put some glue around it if it does fit.
Your best bet is to get a used manifold, take it apart and clean it thoroughly and be very careful not to damage the hose connection.
When I did this job, I cut off the hose at a few inches, coated it with the liquid plasti-dip, then spliced in some new MB vacuum hose to the original length.
I have a spare 430 manifold. $100 shipped to USA48 if anyone wants it.
Brand new manifold is about $1000, but might be worth it if you love the car and don't want to spend hours refurbishing a used manifold.
