Removing rear badges.
Old Apr 26, 2007 | 04:30 PM
Gundo's Avatar
2001 CLK430, 2012 CLS550
Hi guys, what is the best way to remove badges. I want to get rid of the clk430 badge as well as an amg badge someone else added to this car.
Is it as easy as using a hair drier then pulling it off? Will it leave remnants or a faded paint impression? Do I need to have a professional do it?
Thanks,
Old Apr 26, 2007 | 04:34 PM
deyainrdy4ds's Avatar
w208
Thanks,
i dont think....u can ezily remove the badges with floss or thin string or somtin....but wen i tried...there was a lot of stubborn gunk ...i got most of it off but it still didnt look rite....
ima jus have mine professionally done...
Old Apr 26, 2007 | 05:17 PM
Amir_AMG's Avatar
Veteran: Air Force
2000 SL500
i used an old id card, a hair dryer, and i polished off the leftover with one of those sander/polishers and some wax...took it off clean no left overs...its 99 so it was kinda old already if your car is a bit newer, take it to a professional...
Old Apr 26, 2007 | 05:48 PM
CHB's Avatar
CHB
'79 300D, '85 300Dt, '99 CLK430
I used a hair drier, and dental floss. To get rid of the residue I used "goo-gone" followed by polish and wax. The car looks perfect. All you need is a lot of time and patience. Good luck
Old Apr 26, 2007 | 08:11 PM
Gundo's Avatar
Cool, maybe I'll take it to the pros and see what they charge for the 2 badges. If its too much I'll give it a go.
Whats a good price? $50?
Old Apr 26, 2007 | 10:34 PM
The Jury's Avatar
2002 c240
OK guy, before you screw your paint up by overheating it or scratching it........
First go purchase a bottle of GOO GONE. It can be had at most any hardware store, maybe walmart, and places like home depot, lowe's, etc.......
http://www.magicamerican.com/index.aspx
After you have the goo gone, start removing your badges by taking a hair dryer and using LOW HEAT to warm the badges up.
Use dental floss to slide under the badge after it is completely warmed evenly all the way across.
Use a soft cotton rag and soak the tip with goo gone. This stuff dries quickly so you'll have to reapply it to the rag often. Wipe the area with goo gone over a few times and then go over it a final time and wipe clean.
Wax the area with a good wax and you're done.
Old Apr 27, 2007 | 12:50 AM
Gundo's Avatar
Jury, dude I've used goo gone for years. I have a bottle right now. If the pros shoot too high I'll do it myself. Thanks for the info though.
Old Apr 27, 2007 | 12:51 AM
Gundo's Avatar
Oh, I also have a can of mothers wax.
Old Apr 27, 2007 | 12:55 AM
The Jury's Avatar
2002 c240
The pro's have a bottle of Goo gone and some dental floss.
I'd know, I worked detail for a huge car dealer for years. It's the "correct" way to do it.
When they are done waxing they'll rub some of that instant shine spray wax over it and shoot it out the door.
Old Apr 27, 2007 | 02:24 AM
Gundo's Avatar
Cool, looks like I'll have to do it myself.
