for those of yall w/staggered tire set up...
25k on each set of tires. is this normal?? ive noticed that the inside always wears out at about 12-15k mi. and then i rotate the two front with each other and also the back so they can evenly wear out.i just bought my third set. heres the question, is this normal?? do i need an alignment? camber kit? thanx for all your input
It also depends on the brand of tire you use, too. I go with Michelin or Goodyear Eagle F-1s. I tried some Yokohamas a while back and those POS tires went about 10,000 miles before crapping out.
Make sure the alignment is good and you'll be fine.
and for the person that asked, i get charged around 30buks to rotate my tires. just go to an independent shop. if u go to a big chain tire shop,they are bound to charge u an arm and a leg,esp. cause its a mercedes. for some reason, they tend to think we **** money just cause we drive mb's,lol
