Wats Da Biggest Staggered Rims Size I Can Run On A 208
P.S. WATS DA BEST SUP, TA RUN TOO THANX MATTY MATT
i dono if u cud get 20x10s in the back....but mine are 18x10 and fit fine...so im thinkn 20x10 shud fit fine too since its the rear...
1. Only lower you car with H&R or Eibach...no extra lowering with spring pad swaping or cutting of springs until you have your wheels installed.
2. Wheel sizes can be 20x8.5 and 20x10 or 9.5.
3. Rear Offsets should be in the range of 30mm to 40mm...25mm would be the max but you could possible get some minor rubbing.
4. Front offsets should be in the range of 32mm to 38mm.
5.Front tire sizes should be in the range of 225/30/20 or 235/30/20 or 225/35/20 or 235/35/20.
6. Rear tires sizes should be 255/30/20 and 245/30/20.
Should you decide to go as low as you can go with the spring pad swap depending on what offset and tire size you go with up front you will have a little rubbing that will require front fender rolling, but if you keep it to the bare minimum like I have advised you will have no problems.
Hope this helps. If you're interested in purchaing some really nice wheels let me know and I will hook you up. You will have no issues with my set up because it was made to clear an aggressive drop. And you would be buying wheels from a person who really takes care of their wheels. The wheels are always spotless so that means no brake dust spotting nor is there any scratches...just one minor scuff but nothing that should stop you from turing down such a good deal. 20's look the best on a clk because 19's look ok but you always feel like there is something missing after you walk away from the car or when you're walking up to it, I figured out that 20's was what was missing. Think about it.
What's your opinion on 19 front and 20 in the rear? Cuz 19's fit w/ lowering (not as low as yours, but standard lowering springs and shocks) and look good in the front, but 19's seem small in the rear. Do you think you could do 19x8.5 front and 20x10 rear w/ no modifications and lower it? I was thinking the rear has more clearance...
As long as there within a reasonable amount it will be fine.
I just put 20 inch amg monoblock styles 20/10 rear fits fine with 40 offset.
did you change your spring pad sor anything?
I do still have my wheels...I never sold them because the wheels I wanted were way to expensive and I didn't want to come up with the rest of the money after selling these.
I do have my eye on some wheels that are not so expensive though..make me an offer and I may take it.
I agree that CLK w/20's dropped looks absolutely sick, but wouldn't that also degrade your cornering ability?
Thank you in advance...
