Beating the crap out of my CLK 430
Old Aug 8, 2007 | 03:03 PM
Houman's Avatar
whats up fellas,
I'm a pretty active driver with my 430 cab. i used to own a 240sx drifter and always love brigin that back end around.
On my way to work this morning I drifted across two lanes in 1st gear and selected second and then bang the car bogged out as if someone threw a stick in the tranny and all lights on the dash came on "ABS, SRS, ABC, DVD, MP3, VCD, VCR, the works man. also to add on the information council a battery and alternator light as well. my stereo also cut off for a split second as well.
GUYS, whats up? should i take this car to the mechanic or perform exorcism!
Old Aug 8, 2007 | 03:58 PM
MarcusF's Avatar
2002 CLK430
I think you should plug in an OBDII reader.
Old Aug 8, 2007 | 04:17 PM
Houman's Avatar
i unhooked the battery for about 20 min hoping to reset the computer, no difference!
i just came back from a euro shop close to my shop and the guy is pretty honest. he said that he wont be able to read anything if nothing is constantly displayed on the dash, which i figure he's right since the car only acts up when i take 1st or any gear to high rpm, when i slow to normal rpm the abs light turns off and the car operates normaly!
i just did another test,
i selected 1st gear from start and punched it, as its accelerating hard even at 3 to 4 rpm the abs light turn on.
i spoke to a auto tranny guy and he's telling me that i probably "crunched" the tranny, i guess thats his way of saying its done for.
Old Aug 8, 2007 | 04:18 PM
Houman's Avatar
whats the OBDII reader, can that read anything without it being displayed on the dash?
Old Aug 8, 2007 | 04:23 PM
Houman's Avatar
guys you gotta help me out man, I'm takin out this hot russian chick this weekend and wanted to surprise her with the 430 cab, then maybe i'll get a surprise! otherwise i'll be pushin a pontiac G6 from budget and then i'll be G'd out!
not sayin i need the ride to hit it up but work can go alot faster with a few tools!
Old Aug 8, 2007 | 04:52 PM
ThrillKill's Avatar
CLK/ML
Not to make you lose your boner but a new tranny is like 4k.
Old Aug 8, 2007 | 05:06 PM
Houman's Avatar
hey hey,
we will not have this kind of talk on this thread! even if it is the truth.
you think even if the car drives normaly at regular speeds it could still be a mechanical problem?
i just bought a set of rims and i'm not gonna have anything to put them on!
Old Aug 9, 2007 | 12:19 AM
Houman's Avatar
i spoke to a buddy of mine with a 330i and he thinks its the limited slip esp system. it sounds right since the esp abs light comes on when i push the car and wheels start acting harsh.
Old Aug 9, 2007 | 12:36 PM
Houman's Avatar
guess what,
drove to work this morning and everything was fine, no bas light nothing wrong with gear changes, everything seems fine?
this leads me to believe its a computer controll problem.
does anyone know if the rear wheels are controlled by any eletronic or lsd component that i should look into.
any input from you pro's would be helpfull....
so far i feel like i'm writting love letters to myself!
Old Aug 9, 2007 | 04:18 PM
MarcusF's Avatar
2002 CLK430
The CLK has an open diff, so it's not an LSD problem. An OBDII (on board diagnostics, version II) reader will read the codes that the ECU stored when the lights on your dash came on. You look up the codes to see what the problem is. For example, if the code reader (OBDII reader) says P0114, then the intake air thermosensor is either bad, or the wiring to it is bad.
Personally, I'd open the trunk and look at the date on the battery. After seeing that it's 5+ years old, I'd call Mercedes at the 1 800 number and have them change it. Then I'd take it to the dealer and see if VIN on the car is in the range for the voltage regulator recall. That's because low voltage from a bad battery can cause any number of intermittent problems, and voltage spikes from a bad voltage regulator can cause intermittent problems, followed by a permanent error when the ECU gets fried.
Old Aug 11, 2007 | 08:10 AM
Houman's Avatar
Thanks Marcus,
would only dealers have an obdII reader?
Old Aug 12, 2007 | 01:14 AM
MarcusF's Avatar
2002 CLK430
No, actually, OBDII readers are available all over the place. Manuals Unlimited has them for $80. They used to be $50, but that's another post.
He're a link. http://www.manualsunlimited.com/inde...23523406d21ce7
I offerred to sell mine for $60 just the last week. Unfortunately, the subject of Digimoto came up, and all of a sudden, no one wanted mine. The Digimoto reader is way better than my reader, and if I needed a reader I certainly wouldn't buy mine, but it is available.
Old Aug 14, 2007 | 06:58 PM
Houman's Avatar
thanks for your honesty bro,
you know i was about to buy a xkr before my 430 and I'm glad i went with the benz, you guys on this forum are alright.
Old Aug 22, 2007 | 09:52 PM
SoCalw11w123's Avatar
yo,
when I had the 17" stockers on my clk did the same thing (all dash lights)after flooring it with ESP off, at a stop light....
I stoped the car, and gave it a 5 minute break, and it was all ok.
now I roll on 19"s and it no longer peels out..=( (just a weak tire chirp)
Old Aug 23, 2007 | 01:01 AM
riannausa's Avatar
2001 CLK430 & 2007 350Z
guys
how much does it cost to change the battery????
Old Aug 23, 2007 | 02:44 PM
deuxslow's Avatar
W215
Originally Posted by Houman
Thanks Marcus,
Go to Autozone. They loan them out for free.
Old Aug 24, 2007 | 12:54 AM
DevilsAngel's Avatar
CLK 430
ya but autozone's readers suck and aren't as good. when I had my Audi TT I took it there to read the codes it didn't work. I personally would either just buy one or take it to a German car only shop to have them read the codes.
