Spark plug wires
Old Sep 29, 2008 | 02:01 PM
lupo7791's Avatar
2001 clk320
Spark plug wires
Quick question, should I replace the wires when I do the plugs the car has approx. 107k. I'm getting different stories the dealer says they should be replaced as there is chance that they might misfire afterwards, but an indy shop I talk to said is not necessary unless I'm having issues with them now. I'm puzzled Any suggestions welcomed.
Old Sep 30, 2008 | 01:16 AM
MarcusF's Avatar
2002 CLK430
If the wires are fine now, and the person who changes the plugs knows what they are doing (there is a plug wire tool), your wires will be fine when the plug change is complete.
Old Sep 30, 2008 | 11:04 PM
babyboigsxr's Avatar
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
Having the EXACT car as you and the EXACT mileage as well. I would recommend changing them to something high end. You'll notice that your car will idle so smoothly that it'll be like your car isn't even on.
Be sure to get the DENSO IRIDIUM Spark Plugs or the NGK IRIDIUM Spark Plugs with the wires.
I bought the $400+ EvoSport Wires, and man.... way better. That doesn't even include the 12 IRIDIUM plugs.
Old Oct 5, 2008 | 05:37 PM
Wobert's Avatar
Happy owner of '98 CLK 320
Since I am a cheap *******, I am not about to change my spark wires before I think they are getting "old".
So, anyone know if there is a mileage timestamp only, or if there is also a timestamp in years? I have a '98, but its only on about 20K miles.
Wobert
Old Oct 6, 2008 | 12:13 AM
sfclk's Avatar
1999 CLK320
i didn't replace wires when i replaced plugs. if i did replace them, i would use autohausaz.com
Old Oct 14, 2008 | 08:14 AM
ematz's Avatar
2001 CLK55 AMG
I replaced my spark plugs without doing the wires. I later replaced the wires with the Magnecor 8.5 mm wires. They're awesome by the way.
I do agree that if you're mechanic says you're original wires are fine then I would go with that. Keep in mind however, they don't last forever. And as for the dealer, of course they want to replace them because it's big money for them. They always want to replace everything.
Old Oct 14, 2008 | 03:45 PM
KENNETH04S's Avatar
02' brabus modified ML500,05' Lambor Gallardo, 02' CLK
i got them replace by dealer last month or so. i was got a rough idle, took it there and they found out 3 of my cyclinder got misfire due to bad cable. end up i got them replace a whole set + 3 engine mounts, my car still under starmark warranty. after it smooth like silk
Old Oct 20, 2008 | 12:25 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I also replaced my wires and sparkplugs with Magnecore wires and Denso Iridium spark plugs. I'm not sure I felt a major difference, quite possibly a placebo effect.
