MAF symptoms
i wrote yoar ago about some problem with speedtronic defekt. But the problem is still here. I was at 5 different MB shops but thay have no clue about the problem. The symptoms are that the car is slow as hell. Than the fuel consumption is a hihger than usual. Than when I turn off the MAF kabel the noise of the car is the same as when the MAF kabel is on.
In the sommer everything was OK and now is again time to time that this happens. Something is also strange that in the channel that goes to the MAF is a lot of oil. It is possible that time to time come this oil to the MAF senzor and this cause the problem??
Please help me i am desperate it is over a year and I still dont have the solution. Can please someone give some sugestion obout this MAF if it is possible that is this the problem or the oil in the channel.
Thank You in a advance.
i know what O2 is but i dont know where I find it in the car. where are these senzors? CEL - do You mean by this the fuse for O2?
floor the car from stop?? i dont understand
the CEL is the orange check engine light?
the O2 sensor is found on the exhaust around where the catalytic converters are up front around the transmission.
what happens when you push the gas paddle to the floor from a light?
the CEL is not on only the speedtronic light come on (it dosent work when this symptoms came up)
can i unplugt the O2? and what will hapen? when is everything OK with the car and i unplugt it than must be the same syptoms as I described?
hmm when I step the pedal to the floor it goes to tde 4500 rpm and than stop there
http://forums.mercedesclub.org.uk/sh...ad.php?t=34036
I have clean the oil out od intire air system and the false is stile here, the speedtronic defekt.
So i made a litle test, everytime I started the car I made the contact and wait a 30 seconds and then is no false, but when I turn the key in a sekond than is in 80 procent the problem (speedtronic) here and the car goes with just half power (the acceleration is disaster).
Somebody have some solution or advise obout the problem consider starting car with waithing 30 seconds?? Is it possible that this is conected wit this ERG thing?
