help with installing springs and pads w208
Old Dec 30, 2008 | 11:26 AM
slickclk430's Avatar
99 CLK 430, 00 SS Camaro 500HP, 95 SC300 Lexus, 06 GSXR 1000
can someone please post the install instructions on the springs and pads for a w208.. just got a set of h&rs and want to make sure i install them correctly and the quickest way possible
thanks... either post on here or can send to my email
06gsxr@gmail.com
thanks to all those who can help
Old Dec 30, 2008 | 05:53 PM
vizionclk430's Avatar
2002 clk430
I did mine but can't remember what I did step for step try looking thru the w208 how to might be in there somewhere
https://mbworld.org/forums/clk-class...8-how-tos.html
Old Dec 30, 2008 | 07:22 PM
hhseouljah's Avatar
2001 CLK 55
do you have the mercedes spring compressor? if not, the only other way that i saw to do it without that spring compressor is to drop the lower control arms, which really shouldnt take much time to do anyways.
Old Dec 31, 2008 | 11:08 AM
i was just going to use a reg. spring compressor.. do i still need to drop the lower control arm?
so if i just compress the springs with the car on on jack stands will they just come out or do i have to do something else?
Old Dec 31, 2008 | 03:26 PM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
IF you are quite good at DIY then you can do this yourself but take extreme care as the coil compressors can be deadly.. The back is no problem and you dont need the spring compressor to remove the coils, as you can just drop the rear arm by placing your jack below and undoing the bolt that attaches to the body. (I had to change my coils and pads 5 times at the rear before I was happy with the drop and therefore got pretty quick at it ! see photos)
The front is harder and requires the compressor, you may also have to undo the damper bolt to get more height in order to remove the coil.
Good luck , do a search on the forum there are hundreds of posts, and one peice of advice MAKE SURE you get the wheel alignment changed after you have finished.
Attached Thumbnails help with installing springs and pads w208-rear-suspensionw208.jpg
Old Jan 1, 2009 | 05:23 PM
k thanks
Old Jan 2, 2009 | 12:46 PM
babyboigsxr's Avatar
E55 AMG (SOLD), EvoSport CLK (SOLD), 2013 GsxR 750 (SOLD)
Be sure to post pics when completed
Old Apr 10, 2009 | 10:39 AM
VerTigo456's Avatar
CLK 430
Any suggestions on the cheapest place to get springs. And for the newbie, can you explain to me what the D#1 pads are that people recommend as well?
Old Apr 11, 2009 | 05:27 AM
A1EK's Avatar
The only place you get them from is the dealer and they are dirt cheap so buy lots in case your not happy with the height !
(PS there's a 1000 posts on this subject so just do a search!)
Old Apr 11, 2009 | 03:15 PM
VerTigo456's Avatar
CLK 430
So you just add or take away pads till you get what height you want?
Old Apr 14, 2009 | 03:24 AM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Cool
No.
There are different number pads ranging from 1 to 5 I believe. Theres is a post around here somewhere with the exact measurements. 1 is the thinnest (more drop) and 5 is the thickest. I have H&R's with #1 pads all the way around. I like it.
Old Apr 21, 2009 | 11:31 AM
VerTigo456's Avatar
CLK 430
Originally Posted by unlukky
No.
Thanks...that is what I am going with. Springs should be here today.
Old Apr 21, 2009 | 12:24 PM
thebender's Avatar
White 1999 CLKL320
FYI many people here are using W210 spring pads because they have thinner pads available.
Old Apr 21, 2009 | 12:52 PM
VerTigo456's Avatar
CLK 430
Thanks for the tip! So go to the dealership and get D1 pads for a W210 then huh?
Old Apr 21, 2009 | 01:58 PM
thebender's Avatar
White 1999 CLKL320
Front
210 321 01 84 (5mm)
210 321 02 84 (9mm)
210 321 03 84 (13 mm)
210 321 04 84 (17 mm)
210 321 05 84 (21 mm)
rear
210 325 01 84 (5 mm)
210 325 02 84 (9 mm)
210 325 03 84 (13 mm)
210 325 04 84 (17 mm)
Old Apr 22, 2009 | 03:05 PM
VerTigo456's Avatar
CLK 430
Front
210 321 01 84 (5mm)
210 321 02 84 (9mm)
rear
You gotta be kiddn me lol. Went to the MB dealership today because the springs came in this morning and they looked at me like I was crazy when I mentioned D#1 pads. Are these numbers above for a 98 - 02 E class? They told me to get model numbers and come back
Old Apr 22, 2009 | 07:38 PM
da_guitarist's Avatar
Current: AMG GT-C. Sold: 01 CLK55, 00 ML55, 01 ML55, 06 E55
these spring pads are for the CLK and E class. The cars are similar in several parts and these are a few of them. Its just a big rubber stopper.
ie, those are the correct part numbers, whether the dealer believes you or not.
Old Apr 23, 2009 | 01:27 AM
sfclk's Avatar
1999 CLK320
Install the springs without pads or with your existing pads trimmed down.
Old Apr 23, 2009 | 10:46 AM
VerTigo456's Avatar
CLK 430
thanks! I will just go back with the front and back part numbers above of the thinnist ones and grab them. I appreciate the help!
Old May 13, 2020 | 02:00 PM
convicted's Avatar
1998 CLK 320
Thumbs up
It took plenty of searching, but this ^^ is EXACTLY what I was looking for. Thanks so much!
