transmission slip when cold???
Old Feb 18, 2009 | 09:42 AM
suggashane410's Avatar
clk,s-500
only when i first start it in the winter for about 3 mins the tranny likes to slip and rev high in 1st gear then switch over at odd rpms...any one else? but after the car warms up its fine.. do i need a change in fluid or to add more fluid?
Old Feb 19, 2009 | 06:12 PM
MilitaryBenz's Avatar
CLS63 AMG S
let it warm up it happens with these clks man, i usually let mine warm up for like 5-8 mins then its good
Old Feb 20, 2009 | 12:41 AM
Japp's Avatar
99' CLK 430
my 430 was doing this, went to the shop and it was low on fluid, cleared the codes and corrected fluid level and it was cured.
Old Mar 2, 2009 | 02:37 PM
rjlawlor646's Avatar
2001 CLK 320
my car also does this when its cold. Once it warms up, its good tho
Old Mar 3, 2009 | 06:30 PM
DropTop208's Avatar
02 CLK 430 Cab
The tranny will hold in first gear longer when the weather is cold so that the cats could warm up faster. As far as slipping, it may be low on oil. Thats the first thing I would check.
Old Mar 9, 2009 | 10:56 AM
chem1441's Avatar
2016 C450 AMG
+1
Theres a difference between transmission slip, and what you are describing. Most modern cars do hold first gear a lot longer when really cold in order to warm the emission systems up as quickly as possible. Once warm though the transmission should shift smoothly and consistently at lower RPM's.
That being said, if you have never replaced your transmission fluid, and you have 60k+ miles on it, you should definately consider replacing it. And remember, a transmission drain and fill is NOT the same as a transmission flush. Make sure you know what you are paying for!!!
Old Mar 22, 2009 | 03:40 AM
Mika83's Avatar
Mercedes-Benz CLK320 MY2000
Is a tranny fluid change recommended on the 2000+ models as well? I thought that this gearbox was maintenance free and sealed?
My car has travelled 90.000 miles and i doubt anyone has looked at the tranny if it's stated in the manual that it doesn't need to be looked after.
Old Mar 23, 2009 | 03:31 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
MB says lifetime fluids, but I would recommend changing it every 35k miles.
Old Dec 30, 2013 | 12:11 PM
doubleblack430's Avatar
CLK430
So dis is normal
Old Jan 6, 2014 | 08:20 PM
lowphat's Avatar
01 LORINSER CLK 430 - 02 KLEEMANN CLK55 - 88 Euro / Jap AMG 560 SEC Widebody - 16 AMG GTS
In the service department's handbook, "Maintenance Free" transmissions filled with "lifetime fluid" are more fully described in the chapter called "Job Security & Retirement Planning"
Old Jan 7, 2014 | 03:46 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
i've got 150K miles now with the same tranny fluid and it seems fine, but then I would not know the differenence until I changed it and Im sure its night and day !.
As for the higher revs when cold to warm the cats, if you find this inconvenient and if you have tiptronic then just bump up the gears manualy for 5mins thats what I do.
