when idleing, car shakes alot?
Old 03-05-2009, 09:37 AM
rjlawlor646's Avatar
2001 CLK 320
the cars always done this, and i never really paid attention to it, but im just wondering what the problem could be. The car runs smooth, but when sitting at a light or idleing, the car vibrates/shakes more than i think it should..why would this be? motor mounts?
Old 03-05-2009, 12:31 PM
C43AMG's Avatar
98 Black C43 , 08' ML320 CDI ,11 E63
Definetly check the motor mounts.
Old 03-05-2009, 01:23 PM
charliev68's Avatar
2000 CLK430
ignition wires and plugs. most likely the ignition wires.
motor mount check:
with the foot on the break and in drive, step on the throttle. if you hear a clunk or knock, it's the mounts.
Old 03-05-2009, 09:40 PM
Jays_Z's Avatar
+1
Old 03-09-2009, 01:38 PM
miguel430's Avatar
2000 clk430
i have the same problem i change the motor mounts and tranny mount and still shakes but when it shakes my rpm niddle don't move so there's no miss fireing or stuff like that so no idea....
Old 03-09-2009, 01:41 PM
C43AMG's Avatar
Have you changed the Mass Ais Sensor ?
Old 03-09-2009, 04:51 PM
jasonowens32's Avatar
Clk 320
Air Mass Sensor and Motor Mounts was the same problem for me... good luck...
Old 03-10-2009, 10:19 PM
FF_EMT's Avatar
02 CLK430, 86 BMW 325, 66 GTmustang, 97 GTmustang
sounds like plugs and wires mine did the same thing when i changed them the problem went away
Old 03-13-2009, 10:16 PM
NFSCLK's Avatar
RED CLK 430 Coupe
Engine Shaking
How many miles do you have on the car? I 'm at 88,500 and mine is doing the same thing. If you stick it in neutral does it stop?
Old 03-16-2009, 12:25 PM
miguel430's Avatar
2000 clk430
so if the Mass Ais Sensor is failing would the engine light turn on?
Old 03-19-2009, 03:29 PM
99CLK320lover's Avatar
CLK320
Motor mounts look good
I have the same problem on my '99 CLK320 w/ 94,000 miles. I just bought the car and the misfire/shake at idle has been there since I bought the car. When I put the clk in neutral or 2-foot it and rev the engine slightly the shaking goes away.
Today I removed the motor mounts (part # A2032410413) and they look brand new . I'm installing my new mounts just for grins. I have replaced my spark plugs and the wires look fine. Is there an idle air control valve that I could clean??? Would a Mass Air Sensor cause the check engine light to come on? I thought a miss fore would cause the check engine light to come on too?
Any other ideas?
Old 04-01-2009, 12:18 AM
riannausa's Avatar
2001 CLK430 & 2007 350Z
Exclamation hey
Mines doing the same thing. shakes like the car's going to die on a stop light but when i put it in neutral and give it a little gas it stops. Also when it does that the lights and radio kinda dims a little then comes back after it stops shaking. What could be causing this??? atleast now i know that im not the only one with this problem.
Old 04-02-2009, 12:40 PM
tnb1786's Avatar
SS Minnow Johnson
that fixed it for me... but i also changed my o2 sensors all four of them
Old 04-15-2009, 06:04 PM
dyos's Avatar
2006 CLS55 AMG(this week)
Car idles rough in park and reverse
All,
As of late I've been experiencing an issue where when I back up or when I'm sitting idle at a stop light I have this loud vibration in my car. It almost sounds like a subwoofer vibration. The car is an '03 CLK55 AMG. When I took it to the mechanic he informed me it was the rubber engine mounts that are wearing away now the engine is starting to rest on the frame. He informed me the cost is going to be about $650. I trust this mechanic as I've been with him for awhile now and he's always taken care of me. I just wanted to run it by the forum and get a second opinion if this sounds correct and if the price is reasonable for that job? Look forward to your responses before I drop it off tomorrow.
Old 04-15-2009, 11:00 PM
C43AMG's Avatar
Originally Posted by dyos
All,
I think $650.00 is high.I would expect a $300 - $400 price on this job.I think the mounts might be $50 each - thats $100.00 One hour max per side - $135 x 2 = $270 $370 total.
Old 04-15-2009, 11:06 PM
dyos's Avatar
He also said why he had it up he might have to change the transmission mount as well? Perhaps you do them both at the same time?
The hardware he said was about $150. So 2 engine mounts plus transmission mount = $488 for services the rest hardware.
$135 x 3 = $405... right? Still a little high?
Old 04-16-2009, 06:46 AM
AMGMB's Avatar
1999 Mercedes Benz CLK430
i actually had the same problem and after changing my motor mounts it was a lot better!! My mechanic charged me only $200 for both motor mounts and install! And i didnt even give him the full 200 lol i think i gave him 180. Im located in north hollywood, ca. But 650 is way too much!!!
Old 04-16-2009, 11:16 AM
dyos's Avatar
I just called Mercedes on this and they gave me a quote of $900 for the 2 engine mounts and transmission mounts. Even if $650 is high it's worth making sure the job gets done right I suppose.
Does anyone else have a 2003 CLK55 AMG? I have about 100k miles on it now and I'm starting to wonder if it would be worth me purchasing some type of warranty service at this point. Does anyone have a warranty company they've worked with that turned out to be a good deal?
Old 04-16-2009, 11:54 AM
DropTop430's Avatar
02 clk 430 cabrio
warrenty? whats that? never heard such thing with my clk lol
Quick Reply: when idleing, car shakes alot?
