What a 6.2 liter V-8 looks like 5 weeks from completion.
Old Feb 24, 2003 | 05:02 PM
Sleestack's Avatar
Allright, i already posted this in the Performance forum, however, since my car will be based on the W208 I'm posting it here. This is a picture of my bored and sleeved engine block which means the engine should be complete in a month or so. I know it is not much, but for me its a significant milestone in the production of my car so I was pretty psyched to find the picture in my inbox this morning (thanks Mr. Vanos):
Old Feb 24, 2003 | 05:26 PM
JamE55's Avatar
Out Of Control!
sleestack
Just curious. Where did the block came from is it like from Germany and how long did it take to be received?
Old Feb 24, 2003 | 05:49 PM
Pierre32///AMG's Avatar
Porsche Turbo Stage 4, Cayenne S ... gone C43, C32, ML55 & Ducati 999.
Sweet!!
Old Feb 24, 2003 | 06:39 PM
IDOITBST's Avatar
I Would be more than
stoked by that pic damn your car is gonna be offffffffff the hook..!!!!!!!
Old Feb 24, 2003 | 07:30 PM
LowRydeR's Avatar
That's sick.
-Bruce
Old Feb 24, 2003 | 08:23 PM
Vadim @ evosport's Avatar
C32 AMG
We designed all of the parts locally. The bore is the same as AMG 55 block at 97 mm. But the block is a lot stronger, now it can handle boost.
Old Feb 24, 2003 | 11:32 PM
Dave OH's Avatar
R170
How much?
Old Feb 25, 2003 | 12:54 AM
Mach430's Avatar
The 6.2L Kleemann conversion is just part of the project Sleestack is undergoing. If you are serious about an estimate for the engine, cage, coilovers, or any other portion/combination of upgrades for the car, please email me at ben@evosport.com.
Thanks,
Ben
Old Feb 25, 2003 | 04:04 PM
Dave OH's Avatar
R170
well ben, I am acutally considering a project much like Sleestack's CLK for my SLK... but that's not for a few months... the how much I was referring to (i should have clarified) was boost...
Vadim said that the block is much stronger now... so how much boost can it handle / how much boost will Sleestack's car be running?
Old Feb 25, 2003 | 04:20 PM
Lucas's Avatar
It more a question of how much boost the S/C can create and which compression ratio Vadim have chosen for this engine.
Old Feb 25, 2003 | 04:36 PM
Larry Sonsini
Guest
Posts: n/a
Originally posted by Dave OH
well ben, I am acutally considering a project much like Sleestack's CLK for my SLK... but that's not for a few months... ?
Hmm sleestack style upgrades on a short wheelbase 170? Better have your track suit, helmet, and fire suppression system ready at all times! That would be nuts!
Old Feb 25, 2003 | 05:00 PM
C32 AMG
The CR should be at 9:1, and we are aiming for around 9-10 psi.
Sleeving the block makes it a lot stronger vs. open deck design that MB uses.
Old Feb 25, 2003 | 05:34 PM
Lucas's Avatar
Why not higher CR and lower boost ????
How will you make the 2,0 L MX 420 S/C deliver enough for 6,2 L engine displacement ?????
Old Feb 25, 2003 | 05:53 PM
C32 AMG
Lucas: In California we have what is known as 91 octane gas. In real life it is more like 89. Plus there are always dishonest gas station owners. Getting a tank of 87 and paying for 91 is not uncommon. To avoid any problems with detonation is the reason I am lowering the CR.
Kenne Bell has extensively tested screw type kompressors. A 2.2L unit is capable of 600-620 at the wheels. Brandon mentioned to me that original unit we have is also 2.2L. So I am basing my R&D of those numbers.
If it is only 2.0L than we probably going to be down to 550-570HP at the wheels.
Care to share any experineces?
Old Feb 26, 2003 | 04:29 PM
bmac002's Avatar
CLK 320
Thanks for all the pictures, this is very intersting to me. Please post as many picture as you can along the way of building up the engine. Pictures of the supercharger installation would also be great.
Old Feb 26, 2003 | 04:38 PM
Dave OH's Avatar
R170
Well, not 100% Sleestack style... there will be no 6.2L V-8's in my SLK ;-)
I was, however, thinking about a 3.8L Blown V-6...
But god, imagine an SLK putting 600-620 HP to the wheels!!!!!!
Old Feb 26, 2003 | 10:33 PM
xyzpl's Avatar
S60R, ML320, W211/E350
It looks beautiful....sob...sob...sob...
Old Feb 27, 2003 | 04:54 PM
Lucas's Avatar
Vadim.
I am just affraid that you run into problems with your project, you may have felt that with my comments over the last few month.
The compressor you have on that car now is a MX 420 ( 2,0 L), shortly a KLEEMANN MX 422 ( 2,2 L) will be avalible, this S/C is used in the new 55 kit and can be build in to the old system.
I can't remember the formula by head how to calculate the boost
of the S/C, I will try and remember it from the office tomorrow
then we can try and calculate how fast you have to spin the S/C.
Brandon just build a BRABUS G 5,8, that car runs trouble free with
a 0,4 - 0,5 bar in boost and my guess will be CR at 10,5 - 11 : 1.
You want to double that boost to a 4-500 ccm more displacement.
Old Feb 28, 2003 | 06:10 AM
theine's Avatar
2014 GLK250 BlueTec & 2009 ML320 BlueTec
Sleestack, why are the mods for your car taking so long? Are they having problems getting the parts?
Old Feb 28, 2003 | 09:50 AM
JamE55's Avatar
Out Of Control!
It takes a lot of R&D for this kind of caliber engine to be built that's why it's taking so long. This is not your ordinary engine!
Old Feb 28, 2003 | 12:46 PM
Mach430's Avatar
It takes much longer to build and test parts than it would to simply follow other's examples by buying from MKB.
Old Feb 28, 2003 | 12:48 PM
C32 AMG
Lucas: I see your point. I have talked with Jim Belle at Kenne Bell and he confirmed that even at 2L there should be enough air flow to make 550-600HP.
Is there anything available form Kleemann above 2.2L? Kenne Belle offers up to 3L.
Old Feb 28, 2003 | 01:21 PM
Sleestack's Avatar
When the project started, Brad informed that it could take anywhere from 6 months to a year. Everything, including the engine, transmission, ecu, suspension, chassis, brakes, interior and exterior, is being altered, so there is alot of planning and production involved. Some of the timing on production of parts is outside Evosport's control and I'm not interested in having them use the same MKB parts that Renntech, Brabus, etc. use. Now that the engine block is complete, things should be moving faster, however, I have explicitly told Vadim to take as much time as he needs. My wife and I have a baby coming in a few weeks so I should be preoccupied and sleep deprived for the next few months. I'm also on the border of having my license suspended so a little time with my Audi A6 4.2 or E320 is probably good for me. I have complete confidence that Vadim and his crew are going to build an absoulte beast that will be well worth the time spent without my w208.
Old Feb 28, 2003 | 01:32 PM
JamE55's Avatar
Out Of Control!
So does this mean your MKB parts are for sale? Just curious.
Old Feb 28, 2003 | 01:40 PM
Sleestack's Avatar
No, the cams, cats and headers will be used. I was actually referring to the block and engine components. MKB parts are great, however, I just wanted to do something a little different witht he engine.
