Transmission Fluid Change & TC flush, parts ???
Looking for parts on the net. Want to be certain to get the right ones. Can anyone kindly give me the OEM part numbers for the gasket, filter, magnet, dipstick tool. Especially the magnet--can't find it anywhere.
Here are the parts for Transmission Fluid Change & TC flush: Transmission 722.623
Fluid (15 Qts.): Valvoline MaxLife ATF $4.99 (Recommended replacement by MB, Replaces MB OEM Fluid, $18.99 OEM Part # 001989210310)
Drain Plug Seal Washer, OEM Part # 1402710060
Pan Gasket: Need MB part #
Pan Filter: Need MB part #
Pan Magnet: Need MB part #
Dip Stick Tool: Need MB part #
PS. Please, no grief on the fluid. See posting #62 in the following link:
http://www.benzworld.org/forums/w210...-tranny-7.html
Transmission oil filter - part number 140-277-00-95
Transmission fluid measuring tool - part number 140-589-15-21
I think you'll need a new lock pin - part number 140-991-00-55
Isn't the magnet cleaned and reused?
I still need the magnet part number for this trans (722.6xx). Am not replacing magnet. Am installing one. In another example of brilliant German engineering, the same Poindexters that have since backed off the lifetime trans fluid concept, also chose to assemble this trans without the magnet.
If you have the magnet number, then I would greatly appreciate your help.
Again, thanks.
The last post on the R129 forum is from a guy who snapped off ALL six studs. The manual says 8 Nm.
Pan Magnet OEM Part # 220-271-00-98 or A169-371-00-03 ???
Another question: Have heard/read about some other job to be done at same time as dropping the pan. Something about a seal on an electical fitting leaking and trans fluid migrating up the electrical line.
What other additional job(s) or inspection(s) should I do?
Again,
$45 shipped, and it's yours.
albertrtsai@yahoo.com
Here's the link:
https://mbworld.org/forums/clk-class...connector.html
B. If you don't find it in search start a new thread appropriate to the subject.
C. you purchase the special mb dipstick and follow the directions you found in A.
