Hardwire Ipod to stock headunit?
Old Dec 14, 2009 | 05:31 PM
rjlawlor646's Avatar
2001 CLK 320
A friend of mine has a 99 camero and he was able to hardwire his ipod to the back of his head unit by interrupting the cd receiving wire. So he has to have a cd playing, but the ipod is whats picked up by the head unit. Is there any way we can do this in an 01 clk? Is there any way to do it without the cd playing because i dont have the actual changer that holds the cds?
Old Dec 14, 2009 | 06:38 PM
gregory13lil's Avatar
2000 CLK430
Do you have the NAVIGATION unit? If so then take a look inside your glove compartment on the right hand side. You should have a input jack there for your IPOD.
Greg
Old Dec 14, 2009 | 11:26 PM
2001 CLK 320
No, i have the basic bose unit
Old Dec 15, 2009 | 06:27 PM
onlinealias's Avatar
CLK430
You can install a Dice, a Dension, or a Soundgate. The differences is in features and whether or not they can be controlled by the steering wheel.
http://cgi.ebay.com/Dice-Mercedes-D2B-5V-iPod-Car-Integration-Adapter_W0QQitemZ360216836830QQcmdZViewItemQQptZOt her_MP3_Player_Accessories?hash=item53de98bade
http://cgi.ebay.com/ebaymotors/SOUND...item5d273d5418
Old Dec 16, 2009 | 08:14 AM
douginky's Avatar
2001 CLK55AMG, 2006 E350 4matic, BMW '79 E24 turboed '91E34 turboed
I'm using a cassette adapter in the short run. Works good if you don't mind seeing the little wire running out of the cover...ipods in the storage pocket below heat controls.
Old Dec 16, 2009 | 07:10 PM
2001 CLK 320
i dont have a tape player either haha
Old Dec 16, 2009 | 09:02 PM
CLK430
I thought tape player is standard. I think you will find that if you hit "tape", the front door will open and it does indeed have a tape slot...
Old Dec 16, 2009 | 09:24 PM
clk430convert01's Avatar
2002 CLK55 AMG cabriolet
I've been using the soundgate auxiliary input box for 2 years with my COMAND unit. It takes place of the CD changer fiber port. It fires up every time and inputs CD-quality sound. Paid ~$250. I do recommend.
Old Dec 16, 2009 | 09:25 PM
JapSpec's Avatar
W208 CLK320
or for now you can pick up a FM ipod tuner and just run it off the radio signals
Old Dec 17, 2009 | 12:12 AM
2001 CLK 320
haha i always wondered why it said tape, but im almost positive there isnt..thats wierd
Old Dec 28, 2009 | 01:34 PM
funky102's Avatar
2000 CLK 320
you do have a tape deck. if you search the forum, theres a way to open up your head unit and solder some AUX wires where the tape signal goes in. this way, you can have an aux wire (which you plug into your mp3 player) every time you hit 'tape' on your head unit.
Old Jun 22, 2010 | 11:46 AM
2001 CLK 320
I'm not sure what type of unit the 01 clk 320 comes with..has anyone tried this?
https://mbworld.org/forums/audio-ele...-complete.html
Old Jun 22, 2010 | 12:25 PM
rediahad's Avatar
mgLipGD
wait that guy at the top said that if you have navigation you should have an ipod port in your glove box? please someone elaborate
Old Jun 22, 2010 | 12:44 PM
2001 CLK 320
i'm not sure because i don't have the navigation, but if you read through the thread i attached to my last post it mentions something about a wire next tot he passanger side door near the glove box somewhere
Old Jun 22, 2010 | 01:46 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
press the serv button on your command and navigate to aux then select. In the glove box there is a 3.5 jack to plug directly to the command. The preset EQ settings are different from the radio and cd so you will need to re select when in aux mode. All you need is a Male to Male cord and your good ta go!
Old Jun 22, 2010 | 01:48 PM
rediahad's Avatar
mgLipGD
where is it located is it hidden cause i can't see it anywhere
Old Jun 22, 2010 | 01:57 PM
2001 CLK 320
the connector hole is in the glove box but the plug is underneath the door sil. look for a circle outline on the right of the upper glove box shelf where the CD changer is. you'll need to pry out the glove box covers and foot well and door sil panels to connect the plug. i don't remember the part #... someone posted it in another thread.
this was from someone that drives an 02 c230..im not sure if its the same
Old Jun 22, 2010 | 02:24 PM
bobbyjo9's Avatar
Are you sure you have command?? It's not hidden and is mounted on the right hand side towards the front of the glove box.
Old Jun 22, 2010 | 03:13 PM
rediahad's Avatar
mgLipGD
Ya my nav sais command on it
Old Jun 22, 2010 | 04:34 PM
bobbyjo9's Avatar
I dunno.. maybe it didnt come on the 01's? Should be a simple upgrade for you though. I forget where I saw the thread, but there is one on retrofitting the plug in the glove box. The interface is located in the passenger kick panel area. The write up was very through and included part#'s as well. Do some searching and im sure you will come across the details but should be straight forward since you already have command
Old Jul 3, 2010 | 10:11 AM
nicgentile's Avatar
2000 CLK 430
Talking
Thanks a lot for this post guys!
I have a 2000 CLK 430 and was so excited when I read about the aux in the glove box that I ran outside to check and there it was!
simply awesome!
Old Jul 7, 2010 | 09:01 AM
Pancho's Avatar
2000 CLK430 Cabriolet
Regarding: Year 2000, 430 CLK Cabriolet
Need some clarity on
"...retrofitting the plug in the glove box. The interface is located in the passenger kick panel area..."
I do NOT have the Nav system. I have the Bose system with CD changer in the trunk. No interface in the glove box.
Questions:
Is the interface located in the passenger door sil, still there for a NON-Nav system ?
In other words, can I expect to find a cable I can patch to, in the door sil, on a NON-Nav system ?
I'm going to also make this query as a topic.
Old Jul 7, 2010 | 09:12 AM
aqua190's Avatar
11 E550 Conv
no nav, no interface. sorry
Old Aug 2, 2010 | 08:46 PM
johnnyinspain's Avatar
CLK430 Convertable
Am I right in thinking there are 2 types of Nav this car can have? Full Command with the large screen, or Nav built into the smaller head unit? I have Nav, but no Command, ie the smaller unit on my 2001 430. No socket in the glove box though....
