oil change/tune up
Old Jun 14, 2010 | 06:55 PM
2001_clk430's Avatar
CLK430
oil change/tune up
hi guys, i just recently got a 2001 clk430 with 69,000 miles. the owner tell me that he get it service every 10k with a mobile 1 oil change synthetic. i am guessing mobile1 should get it change every 5k miles? and also do you do oil change yourself? i rather do it myself then bringing it to a mb dealership and get charge like crazy. thanks
Old Jun 15, 2010 | 09:07 AM
tomtomtomtom's Avatar
02clk55///2010GLK350
lots of posts on this issue...do a search...easy diy...synthetic/10K miles is fine...5-40w mobil 1...8 1/2 qts
https://mbworld.org/forums/e-class-w...ree-parts.html
hope that helps
Old Jun 15, 2010 | 03:49 PM
CLK430
is this the filter i need and the oils? i am planning to get the mobile1 from costco. the dyi said 0-40w, which one is preferred, i live in Cali with good weather? thanks
http://www.autohausaz.com/search/pro...20Filter%20Kit
Old Jun 15, 2010 | 04:18 PM
CLK430
Also will this work even though it say 5-30w, and how many of those 5 litter would i need? thanks
802212
TOTAL/Elf
Engine Oil; TOTAL Quartz Energy 9000 0W30, Full Synthetic; 5 Liter
A fully synthetic motor oil formulated to meet or exceed German car manufacturer specifications for all gas, diesel, turbocharged, and multi-valve engines: BMW Longlife LL01, Mercedes 229.5, Audi/VW 502.00/505.00, in addition to ACEA04: A3/B3/B4. Please verify owners manual recommendations prior to ordering.
http://www.autohausaz.com/search/pro...8@Engine%20Oil
Old Jun 15, 2010 | 07:11 PM
get the Costco oil..need 8.5 qts...just buy the filter (you don't need the housing on is on your link)..afer you unscrew the housing, you slip off the old filter, replace the 3 "O" rings on the housing, and then slip on the new filter. Pour the oil directly into the filter tube (avoids mess pouring into oil fill cap).
I use a suction vacuum to remove the old oil...saves getting under the car)
Old Jun 15, 2010 | 07:46 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Changing the oil / filter is a very easy DIY.
I only use the Mann (OES) Polyester Fleece Media for extended Extended Service (not the paper types) and Mobile 1, 0W-40.
It's the same filter sold by the MB dealer (in MB package and part number) and they only use Mobile 1, 0W-40. The faster a thin film of lubricant gets on the surfaces, the better and the wider range provides more protection.
All the filters some with (5) O rings now.....the W208 only uses (4) and the W209 uses all (5). Make sure the large one is seated properly, in the grove and not up against the cap lip (otherwise it will leak).
I've found a pump that attaches to an electric drill, to suck the old oil out of the dip stick tube, to be far faster and easier than a vacuum type
Old Jun 15, 2010 | 10:40 PM
CLK430
and you guys change it every 10k miles? do i need to do anything else to the 10k miles service beside oil change? and how do get rid of the pop up on the car that say i need mainance? thanks
Old Jun 15, 2010 | 11:27 PM
I do it around 8000 only because I have nothing else to do....MB recommends 10,000 which is OK. Read your manual under fss resetting....pg111...basically, call up the service interval using your wheel buttons(same menu as speed/mileage...), press the "r" button on left side of cluster for a few seconds...you'll get a message and just confirm "yes"
Old Jun 16, 2010 | 01:02 AM
CLK430
I don't have a phone in my car, can I call it from my cellphone? To reset? Thanks
Old Jun 16, 2010 | 08:34 AM
Haven't got a clue what your talking about..what has your phone got to do with anything dealing with oil changes and resetting? If you are referring to "calling up" in last post...please get out your manual and read how to do it.
