Vibration in Steering Wheel
Old Jun 21, 2010 | 01:22 PM
tastoto's Avatar
ck430 2002
Question Vibration in Steering Wheel
when im drving say about 100mph then slow down to 80mph my sterring wheel shakes its not my balancing or tracking or tyes as i have checked these what could it be really confused
Old Jun 21, 2010 | 01:25 PM
rjlawlor646's Avatar
2001 CLK 320
when you say slow down are you using the brakes?
Old Jun 21, 2010 | 01:27 PM
mikekuriger's Avatar
2010 C63
you're driving too fast.
Old Jun 21, 2010 | 03:55 PM
tastoto's Avatar
ck430 2002
no not using the brakes just taking foot of accelarator
Old Jun 21, 2010 | 05:09 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
EITHER ALIGNMENT OR ROTOR OR BALL JOINT ..I KNOW THOSE 3 CAUSES THE CAR TO VIBRATE.
MINE IT USED TO VIBR BELOW 70 AND ABOVE 70 SMOOTH .
Old Jun 21, 2010 | 05:25 PM
tastoto's Avatar
ck430 2002
what ball joint
Old Jun 21, 2010 | 08:38 PM
Originally Posted by tastoto
what ball joint
The ball joint is in the lower control arm to which the strut is attached to.
Old Jun 21, 2010 | 08:40 PM
it looks like this ...
http://parts.carpartsemergency.com/b...ame=ball_joint
Old Jun 22, 2010 | 06:28 PM
mrgoodcat66's Avatar
2002 clk320
Whats that??
Old Jun 22, 2010 | 07:13 PM
tastoto's Avatar
ck430 2002
those i have replaced already last week could it be the lower control arm?
Old Jun 22, 2010 | 08:47 PM
^ dunno.. ask the mechanic and he should know
Old Jun 22, 2010 | 08:48 PM
u are funny but look at your sig.. NOW THAT IS FREAKING FAST
SLOW DOWN MIKEY
Old Jun 23, 2010 | 08:59 PM
tastoto's Avatar
ck430 2002
its a V8 u cant help it Mikey come on
Old Jun 23, 2010 | 09:09 PM
Old Jun 26, 2010 | 07:09 PM
tastoto's Avatar
ck430 2002
to all of you who have steering vibration its your wheel bearings that are loose and need tightening hows that.
Old Jun 26, 2010 | 09:24 PM
jbenz2001's Avatar
2001 clk 320
Mine does the same thing when I'm around 45mph.I did repack my bearings not to long ago maybe I didn't tighten them enough.I know I do need rotors cuz my steering does shakes when I press the brakes.will try to work on it tom.can the steering damper,steering box have n e thing to do wit it?
Old Jun 29, 2010 | 08:46 AM
tastoto's Avatar
ck430 2002
i did change my brake hubs to new ones asswell the vibration has gone now
Old Jun 30, 2010 | 05:27 PM
jbenz2001's Avatar
2001 clk 320
So I tightened my bearings today and it helped out a lot but I still have aliitle vibration.I check my steering box bolts and also checked me damper.how do I know if my steering damper needs to be replaced.
Old Jun 30, 2010 | 05:52 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
undo 1 bolt.. if you can move it with no resistance it's toast. Honestly though if you havent replaced it's most likely bad.
Old Jul 1, 2010 | 04:43 PM
jbenz2001's Avatar
2001 clk 320
Yeah its never been replaced,I'm on it!
Old Jul 6, 2010 | 02:30 PM
jbenz2001's Avatar
2001 clk 320
Found out that the vibration was due to my rear spacers,to bad I ordered the steering damper already.so I guess that's the next step for better smoothness.
Old Jul 25, 2010 | 07:13 PM
benzobg's Avatar
clk320 2001
I have the same problem and my mechanic told me it's the suspention springs that need to be replaced since my car has been lowered and it's not with the original springs.could it be that causing the wheel shaking?
Old Jul 25, 2010 | 10:55 PM
dlbehrns's Avatar
99CLK320,
suspention springs???? that makes no sense what so ever. Also check out the steering damper. Its like a little shock absorber on the idler arm. an often overlooked fix by MarcusF, the steering box can loosen up and the mounting points/bolts are on the inside of the left wheel. remove the wheel and you should see them. I remember seeing a pic on this forum.
Old Jul 25, 2010 | 11:03 PM
dlbehrns's Avatar
99CLK320,
strut is attached, NOT Big Mike, our cars do not have struts. they have control arms, ball joints as you said and shocks. struts as they are commonly referred to are McPhearson struts where the shock, spindle and spring are all one piece.
