Changing instument lights
Old Sep 27, 2010 | 03:57 PM
kiwikompressor's Avatar
clk200 kompressor 2000 , 230c 1978, Ducati 900ssie, Mitsubishi Legnum VR4, Holden Barina 2006
Anyone know how to change dash lights?
Whats the best way to access the back of the instrument cluster?
The temp read out on the instrument cluster isn't showing the top of some numbers can I replace just the lcd display?
Old Sep 27, 2010 | 09:56 PM
big_mike1979's Avatar
CLK 320 (2001) and 2015 GTR
u need to pull it out.
get a hanger and hook it to the side and pull it.
click on the search and too many threads will pop out
its either the bulb is out or its broken.
if its broken, u need to change the entire cluster which is $1200 or u can solder it, but its hard and i would not mess with it.
my temp is gone completely so i dont care, it bothered me at first but not anymore
Old Sep 27, 2010 | 09:57 PM
here this is how u repair it.
https://mbworld.org/forums/clk-class...-temp-etc.html
Old Sep 27, 2010 | 10:01 PM
go to post # 46 , on how to remove the cluster
https://mbworld.org/forums/clk-class...how-tos-2.html
Hi is the cluster just pushed in?
Old Sep 27, 2010 | 10:04 PM
yes, i just pulled hard with my both fingers on each side and it pops out
Old Sep 27, 2010 | 11:54 PM
nicgentile's Avatar
2000 CLK 430
some of my instrument lights are burned out.
are they a standard type of bulb?
Old Sep 28, 2010 | 12:02 AM
NO, u have to get them from dealer and they are cheap,
exepct the main one for the dig speedometer in the middle, its like $8 per bulb and u need 4 if they are out
Old Sep 29, 2010 | 07:16 PM
Thanks Mike.
Once it popped ( like you said ) it was an easy fix.
I see what you mean about the LCD Ill attack it when I have time to give it 100%.
Thanks again you are a great help.
Old Sep 29, 2010 | 09:02 PM
^ My pleasure and anytime
Old Oct 11, 2010 | 07:58 AM
nicgentile's Avatar
2000 CLK 430
I should be getting my bulbs today...then I'll give pullin this thing a try.
Old Oct 11, 2010 | 08:27 PM
good luck
Old Oct 11, 2010 | 11:21 PM
Its not hard as it seems. watch out for the plug there is only 2. There is a clip on the back that just needs to slid down it does not come off the plug.
Good luck
Old Oct 13, 2010 | 05:21 PM
nicgentile's Avatar
2000 CLK 430
What I have learned:
German engineering is so precise that they can actually compression fit a cluster
There are two bulbs that are the main lights for the instruments.
These bulbs are standard as long as you don't lose the plastic MB socket they are in.
All the other lights (ESP! Brake etc) are non standard bulbs and must be ordered from the MB dealership.
Once the cluster was out it was indeed an easy fix. Now I can see my 120mph at night
