Is it bad to remove catalytic converter
Old Oct 8, 2010 | 06:17 PM
rk5rk5rk5's Avatar
Clk320
I think my catalytic converter is clogged I wanted to remove it and make it a straight pipe coz my check engine light is on... I already replaced maf sensor, crank position sensor... Will this eliminate cel when I have it reset? Hope someone can answer thanks
Old Oct 8, 2010 | 11:48 PM
jbenz2001's Avatar
2001 clk 320
u only can eliminate ur sec cats.if u remove ur primary cats it will cause the cel to stay on at all time.it might just be ur o2 sensors.
Old Oct 9, 2010 | 01:14 AM
MarcusF's Avatar
2002 CLK430
Dump the codes. You could replace A LOT of parts before stumbling across what's actually broken.
Old Oct 9, 2010 | 03:23 AM
jbenz2001's Avatar
2001 clk 320
That is true marcus.
Rk get ur codes read then start from there.then let us know what popped and well be glad to help u out.
Old Oct 18, 2010 | 02:47 PM
rk5rk5rk5's Avatar
Clk320
Exclamation My Clk320 misfires
Hi guys went to have the codes check and what came out was misfire on cylinder 4stored current ,5stored, 6 stored current...we replaced the coils and check for vacuum leaks also switch the coils around but its still on the same side... the problem is when i drive it start on a slow pace its ok then i speed up (flooring it for speed) on a high rev. the car starts to lose power then the engine shakes (CEL on) but when i restart it its back to normal again...only on very high speed the check engine comes on... i dont wanna give up on this car i really want to keep it... pls hope you could give me ideas i havent slept for the past few weeks...
MAF (CHANGED)
CPS (CHANGED)
CATALYTIC (Removed) 4pcs
CLK 320 (W208) 2001 @ 61,000 kms.
Old Oct 19, 2010 | 12:36 AM
MarcusF's Avatar
2002 CLK430
A muffler shop can test the cat by putting a pressure gauge on the primary O2 sensor port.
Old Oct 19, 2010 | 05:09 AM
rk5rk5rk5's Avatar
Clk320
Exclamation cylinder 4,5, and 6
Good news guys problem solved the mechanic got the codes then evaluated everything from the driver side 4 5 6 cylinder that misfires he checked the coils, spark plug, vacuum leaks and found out that the O2 sensor is busted on the driver side and is giving wrong information to the ecu that is why it cuts off around 4k rpm especially when i speed up then the car starts to shake and CEL is ON......... now we replaced it with a new one thank God Black-Bird is back on his wings (CLK) hehe phew! Btw thanks again to all of you who answered my questions...
Old Oct 19, 2010 | 05:43 AM
jbenz2001's Avatar
2001 clk 320
No problem rk,don't froget to remember which coils u replaced so ur not confused if this happens again.also do u think its a good idea guys for him to change his other coils now that he's changed a few?
Old Oct 28, 2010 | 04:12 AM
rk5rk5rk5's Avatar
Clk320
Smile :)
K thanks again guys......appreciate it alot )
