Tires for CLK
Old Feb 17, 2002 | 07:18 PM
GT-55's Avatar
2004 E55
Lightbulb Tires for CLK
Need imput from experienced CLKers about 235/265 tires on 18"wheels. Currently have 55 with worn out 225/255 Dunlop SP9000s on 18" Lorinser LM5s and was wondering if advantageous from handling and aesthetics over the 225/255s. Have there been any problems with electronics with the wider tires as rolling diameter 2-3% greater than stock? Is there any problems with tracking?
Old Feb 17, 2002 | 10:54 PM
CLK430JW's Avatar
2001 CLK 430
Tires
I just put 18' LM5's with 265/35 (Pilot Sport) on my CLK430 and the ride and handling is 100% better.
Old Feb 18, 2002 | 03:03 AM
Mach430's Avatar
If you're getting new tires, I recommend that you go with the Bridgestone SO3. It currently is the #1 tire on the market, and is cheaper than the Pilot Sports.
Old Feb 18, 2002 | 12:15 PM
CLK430JW's Avatar
2001 CLK 430
Question about springs
Mach,
Old Feb 18, 2002 | 12:19 PM
CLK430JW's Avatar
2001 CLK 430
Mach,
I ordered new Eibach springs for my clk. Is there anything i need to know before installing. I want an aggressive look not a lowrider look. Any input would be great.
GS400JW@yahoo.com
Old Feb 18, 2002 | 01:01 PM
Harris's Avatar
My car is lowered with Koni shocks and H&R springs & I had 265 tires with Carlsson 2/5 on my 430 before. The rear didnt rub when I had original PZeros but when I changed to PZero Rosso, it rubbed a little bit. There're two reasons for the rubbing 1) my rear wheels are 10x18 2) the design of the PZero Rosso is more square in the corner.
I've also heard S-03 is the best tire in the market now. IMO Toyo T1-S is not a bad choice either, I favor it more than PZeros. Just to give you another alternative. The design of the tire is very important!
Good luck!
Old Feb 18, 2002 | 01:31 PM
Mach430's Avatar
Re: Question about springs
Originally posted by CLK430JW
Mach,
GS400JW@yahoo.com
You may want to change your shocks to Koni Adj at the same time. Your stock shocks are not designed for a lower/aftermarket ride, and will not be as effective as an aftermarket shock would be.
Old Feb 19, 2002 | 10:48 PM
RJC's Avatar
RJC
Various
S03's
Put on new S03's about two weeks ago, nice tires except I've noticed they like to flat spot if the car sits for a day or two without being driven. I asked the tech guy at the tirerack about this and he said he has heard this complaint about the S03'S before and to put miles on them,they're better but still flat spot more than my Pilots did.
