When should I do an alignment on my CLK?
1) Is an alignment necessary when I upgrade my 16" wheels to 18" wheels?
2) When I get suspension lowering springs like Eibach or H&R springs, will I need to get an alignment (I think the answer to this is yes, but can someone please confirm)?
3) I've been told that when cars are raised off the ground (like for an oil change, etc.) that alignment can be effected. Is this true? How about when I rotate tires?
Or is this all mute because there is some fancy mechanism in the car that will tell me when my alignment is off?
Thanks in advance...
When I lower the car with lowering springs, I'll have negative camber in the rear wheels that I won't be able to fix unless I:
1) Have the upper control arm heated and bent (the old fashion way of doing alignments).
2) Purchase adjustable camber adjustment bolts. $$$
What is everyone's recommendation?
Another alignment question:
