Tires - Pirelli PZero Nero/Pilot Sports/S-03s???
Heres the performance Test Review from TireRack:
Max Performance Tire Test
I'm driving a little more conservative with this set than the last, as they will wear fast if driven hard ( which is my norm ), and hopefully I'll get more miles than I did with the last set: I love the way they handle in rain, as we get a lot of it during this time of the year here in Central Florida, and that was my deciding factor in my choice for my stock rubber. I'm also using 18" Lorinsor now instead of the stock 17 AMG's.
However, my vote goes with the PZero Nero. I got one of the first sets when released last year. I know I was taking a gamble but I have always been happy with Pirelli products. I seem to be in the minority. The traction with the Nero in both wet and dry conditions is great. I got about 20000 miles out of them and I'm pleasantly surprised that they aren't noisy even when worn. I agree that the original PZero (yellow label) was noisy but IMO the Nero isn't noisy at all and the rear tires are almost completely worn. At Tirerack the Nero is the least expensive of the three you asked about. I'll be ordering a new set probably this week.
SO3's or Toyo T1-S.
Pirelli's are loud and uncomfortable. Pilot Sports are loud and wear fast (except for Karl who's new record seems to have raised the average by 5,000 miles
I just had the fronts replaced because I was doing it out of warranty and I didn't want to wait too long before my advisor forgot about the deal....
So, technically, I think I was looking at close to 35,000 miles before my tires needed to be changed... Dang, I must be driving like grandma... or maybe it just has to do with the fact that i SIT in traffic in my CLK, rather than actually driving it 90% of the time...
I bought the Yokohama AVS ES100's, and I think they're the best.
The grip and handling is amazing
This combo essentially yields the same wheel diameter as 19s with 235/35-265/30 setup...
My car is dropped just about exactly 2" front & rear... Any help?
My intentions were to give the Yokohama's AVS ES-100s a try cause my buddy plans to sell me (2) 265/35/18s for dirt cheap (inteded for his Porsche)... I'd go with the S-03s in a heartbeat, but I'm trying to keep things to a budget so my finacee doesn't kick my A$$ if she finds out how much I really spent....
By the way, if I go the route of 18s, and stick 235/40/18 Fronts, and 265/35/18 Rears, am I going to rub?
BTW - I got over 26,000 mile on Pilot Sports on my E55 and I drive like I'm in a race everyday. They would have gone another 3-5K if I had stuck with the recommended inflation pressures.
SO3's or Toyo T1-S.
TIP for ADDITIONAL SAVINGS:
Use the spare tire - mine was Pilot Sport 225/45/17 - as your new front tire and save $200!!
ps
make a used front your spare.
I had simliar pressure's on my car. I think the problem is the amount of pressure I placed on my tires
I'd skip the spare-tire savings... The tire is speed limited to 50 mph.
Yep... according to my manual, its a regular 225/45 W or Z rated tire, so I would assume that if you mount it on NORMAL rims, that it would be ok to use on the fronts...
Isn't the spare tire a regular Z rated tire? i thought the only difference was it was mounted on a cheesy black steel rim...
Of course the spare IS a full size Z rated - a Michelin Pilot Sport tire (in my trunk) a tire sized 225/45/17 - costing $200 plus.
The only reason MB recommends 50MPH is that
1. the spare is a front tire size (the rear tires are 245/40/17) and
2. the spare is on a skimpy rim.
I just had the spare incorporated into my set of 4 new tires of Michelin Pilot Sport.
TOTAL COST:
$600 including balancing, mounting, taxes, disposal fees at COSTCO.
So far, I'm quite happy with the SO-3's. I've tried Pilot Sports too and they just don't last that long (too soft) given the lackluster handling they provide.
Mark, I too was considering the AVS ES-100s. They seem good for the price, with decent tread wear (280)... noise should be pretty low... Jeremy seemed to have had a little bit of bad luck with his set though...
