CLK Rough shift from 1st to 2nd gear
Old Jan 27, 2013 | 01:24 AM
torezcoleman's Avatar
99 CLK 320
Ok so i replaced both the engine mounts and the transmission mount, the car doesnt shift rough from 1st to 2nd all the time but it does it occasionally,and when i move the gear shifter from park to reverse or drive,i can hear a small thud in what sounds like the rear of the car. Any ideas?
Old Jan 27, 2013 | 03:10 AM
MarcusF's Avatar
2002 CLK430
Check the flex discs.
Old Jan 27, 2013 | 06:00 AM
AMG_BENZ's Avatar
None
How many miles that the flex discs could last? Is it easy to fix without lifting the car up?
Old Jan 27, 2013 | 07:36 AM
99 CLK 320
Hey thanks for replying,when i did the transmission mount I took a look at the flex disc and it didn't seem to be damaged,is it similar to the transmission mount as in the aspect of not looking warn or damaged but still needing to be replaced
Old Jan 27, 2013 | 05:00 PM
99 CLK 320
Ok so i went and out and did some more investigating,and again like i said the flex disc isnt damaged,when i did the transmission mount it was a little bit of oil substance on my transmission pan,i cleaned it off,so today when i went to go investigate i noticed that it was some more oil substance on it,i wiped it off again,so maybe its shifting weird from the level being low,im going to further investigate that and then ill get back
Old Jan 28, 2013 | 04:31 PM
99 CLK 320
Sooooooooo it turned out to be the transmission connecter was leaking and needs to be replaced,so tomorrow ill get to it.
Old Jan 29, 2013 | 12:23 AM
MarcusF's Avatar
2002 CLK430
It's a normal wear part and there are 2 of them. One at each end of the driveshaft. Wear is torque and time dependant. They may last 100K or they may last 30K
You'll have to get under the car to check and/or change them.
Old Jan 30, 2013 | 06:46 PM
99 CLK 320
Question
Sooooooo,i couldnt quite find the torque converter drain plug and i gave the engine a full rotation two times,the long way with a pry bar. Anyway i drained the transmission via the trans cooler line,and emptied it out and put fluid in until it was all the new fluid. Changed the transmission gasket filter,and also changed the transmission connector adapter. Drove it, checked the temperature and it was at the proper temperature,and its proper level. Sad to say but the car shifts smooth in the 1st to 2nd,2nd to 3rd,but the 4th gear jumps EVERYTIME. Ive ran out of DIY yourself ideas, and now im going to have to take it to the dealership and get a star diagnosis
