Groceries in Locked Trunk!
2002 CLK430
2002 CLK 430 -- NOT CABRIOLET
Read lots of answers here and elsewhere but none work or apply to me.
-Can't open with remote or interior switch.
-Key won't fully insert so I can't turn it.
-Battery is fine.
Is there anything else I can try?
Can I get in through the back seat?
If all else fails can I drill out the lock, and if so, how does one do it?
Gonna order pizza now.
-Battery is fine.
I had the same problem with my CLK320....tried numerous times with the metal key that is inside the fob and found that you push the key in then turn to the left at around the 10o clock mark then push the whole lock mechanism in and it should open..
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Spray some INOX into the lock, before trying fob key.
http://www.inoxmx.com/inox/mx3-lubricant-food-grade/
Open the first aid kit, make hole in bottom, reach in and release seat....crawl into trunk. You can then see what is jaming the latch.
You might have something stuck in latch...don't use pliers on key, it will break in the lock.
After you get trunk open, spray wd40 into lock..leave for a day and then slowly work on freeing the stuck lock.
I always keep one seat w/red tab showing just in case.
Pliers on the key worked for me. Also emptied a half a can of wd-40 into the keyhole too. Good luck.
Don't force the key to turn with the pliers. Just use the pliers to help wiggle the key in and out and back and forth. Takes like 20 minutes of this before you will get it unlocked. Be patient and don't Hulk it.
