w208 wheel offset
Old Oct 4, 2015 | 11:03 AM
M4dMax's Avatar
02 W208 CLK55 Cabriolet, 2000 W163 ML55
w208 wheel offset
Hi this is my second post on mbworld and I'd just like to say its been really helpful. I have a 2002 clk430 and I'm in the market for new rims. I was wondering if I could fit 19x8.5(f) 19x9.5 (b) boath with a 45mm offset
Old Oct 4, 2015 | 05:53 PM
dbldpr's Avatar
Veteran: Navy
Welcome hopefully someone will be able to answer your question
Old Oct 5, 2015 | 01:27 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Welcome to MBWorld.
Those offsets are too high... ideally you want low to mid 30s for your w208 depending on how aggressive you want your fitment.
Old Oct 5, 2015 | 08:13 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W208 forum...
Old Oct 22, 2015 | 12:00 PM
jonUF02's Avatar
2015 GL550 4matic
My 19's fit perfectly, here are the specs. Offset depends on width.
Model : MRR RW2
Size : 19X8.5 & 19X9.5
Bolt pattern : 5x112
Offset : 32MM (F) & 35MM (R)
Hub Bore : 66.6mm
Lip Size : 2" (F) & 2.5" (R)
Finish : SILVER CHROME LIP
Old Aug 29, 2019 | 06:11 PM
Mitra43's Avatar
2002 CLK 320
Model : MRR RW2
Hub Bore : 66.6mm
I know this is an older post but do you have pics of your setup?
Old Aug 29, 2019 | 06:57 PM
jonUF02's Avatar
2015 GL550 4matic
Pics of when I sold it about 4 years ago.
Old Aug 29, 2019 | 07:32 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Try this
https://www.wheel-size.com/size/mercedes/clk-class/2002
Old Aug 30, 2019 | 09:13 AM
jonUF02's Avatar
2015 GL550 4matic
Here is a link that I've had saved for quite a while, it's very helpful. It will compare your current specs to what you want to buy, then tell you how the appearance and clearance will differ:
http://www.rimsntires.com/specspro.jsp
Old Sep 13, 2019 | 02:17 PM
2MERKS's Avatar
'99 CLK/05 E500 WAG
Status?
R
2MERKS
