Check engine reset
Old Jul 7, 2017 | 01:36 PM
Aivaras07's Avatar
clk w208
Check engine reset
Hello, is there any way to reset check engine indicator without diagnostics tools ? Check engine went on because of missfiring i fixed that problem, but check engine is still on.
Old Jul 9, 2017 | 01:08 PM
cindyclk's Avatar
It will disappear after about 5 starts/100 miles....what did you do to fix the problem?
Old Jul 9, 2017 | 03:58 PM
Aivaras07's Avatar
clk w208
It was missfiring, so i changed spark plugs.
Old Jul 9, 2017 | 07:17 PM
Serndipity's Avatar
2001 CLK320 Cabrio
Have to agree with cindyclk.
When it's a OLB II emissions issue, after a successful repair and 3 cold starts, the CEL will turn off.
However, that occurring , if you're due for a state emissions test, there are additional sensors that need to change to 'ready' in order to pass. After a successful repair, it will take a couple of hundred miles of additional driving to reset the sensors (even though your CEL is off).
If your CEL hasn't turned off after at least 3 cold restarts. that indicates that the necessary repair is still pending.
Alternatively, you can clear the trouble code, with most OBDII scanners and see if the CEL reoccurs.
Hint: Miss-fires are not always due to just spark plug condition.
Old Jul 9, 2017 | 09:30 PM
cindyclk's Avatar
usually not spark plugs.....usually a bad MAF
Old Jul 14, 2017 | 07:50 AM
A1EK's Avatar
SL 350 R230 (3.7L with AMG Speedshift autobox)
Miss firing in my experience is usually not the plugs but an ignition coil.
What car have you got ? If its a 200 or 230 then you will have two ignition coils one per pair of plugs.
Old Jul 15, 2017 | 10:09 AM
Aivaras07's Avatar
clk w208
I already fixed that missfiring like i said it was spark plugs for me. But check engine dont go off and i dont have diagnostic tools to reset it :/ tried to off battery and press and hold brake for about 2 min, nothing happend just radio reset
Old Jul 17, 2017 | 11:48 AM
Serndipity's Avatar
2001 CLK320 Cabrio
Just about every automotive parts supply store has a OBDII code scanner. As a free service, they will scan your codes and clear them, if requested.
Old Jul 17, 2017 | 01:14 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Perform an internet search on "OBD2 drive cycle".
