Check Engine light
Old Apr 10, 2002 | 09:14 PM
BroadSt Bully's Avatar
2000 CLK 430
Unhappy Check Engine light
Greetings All,
After driving today for about one hour with a little manual shifting (city driving and changing lanes : )=
I had a Check engine light come on. Of course at this time with a very sad look on my face call the local dealership for an appointment tomorrow. I reviewed the car’s owner manual for possible clues; however, there was nothing I could resolve myself.
Has this happen to anything else? I checked the gas cap it was not loose.
P.S I have one door speaker that's is not working but that should not be the problem.
NDJ
Old Apr 10, 2002 | 10:18 PM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
Anything can set a Check Engine light on a Benz, there are literally hundreds of different possible causes. You checked the gas cap, thats about all you can do.
Old Apr 10, 2002 | 10:34 PM
gareeb's Avatar
a car
Re: Check Engine light
Originally posted by BroadSt Bully
Greetings All,
NDJ
Has you MAF gone out yet.
I had that happen to me about 1 month ago.
Apparently this is common. At least that is what my tech says.
Old Apr 10, 2002 | 11:01 PM
2000 CLK 430
Re: Re: Check Engine light
MAF means what? 2000 CLK with 23K miles
Old Apr 11, 2002 | 02:03 AM
Newbie's Avatar
MAF= mass air flow (meter) basically measures the amount of air entering the intake.
Old Apr 11, 2002 | 05:35 AM
2000 CLK 430
Okay thanks for the info.
If this is common with OEM what will happen with aftermarket air intake systems as a mod?
Old Apr 11, 2002 | 02:07 PM
JDS's Avatar
JDS
clk 320 1999
Had the same problem last year. it turned out to be a faulty sensor.Dealer replaced it, no problem since.
Old Apr 11, 2002 | 02:55 PM
Angel_Dust's Avatar
CLK 430
more than likely it is a faulty oxygen sensor that is causing the check engine light to come on....i had the same experience a while ago when i was driving a little aggressively on the road....damn thing came on and i thought i broke the car...anyways it's a quick fix at the dealer...they plug their diagnostic computer into your car and then say its an O2 thing and replace in a few minutes....
Old Apr 11, 2002 | 07:16 PM
2000 CLK 430
I'm back from the service center.
The follow items needed to be replace.
Fuel shutoff value
Evaporative purge value (Front)
Thanks for all your ideas and support
I guess the MAF is next
Old Apr 12, 2002 | 07:29 AM
kingman18's Avatar
CLK430
Old Apr 12, 2002 | 12:11 PM
Mach430's Avatar
MB is OBDII (2)
Old Apr 13, 2002 | 12:56 AM
mbtech208's Avatar
All cars sold in the US after model year 1995 or 1996 are OBDII, it's a federal requirement.
Old Apr 14, 2002 | 07:55 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
Ahhhh...don't worry about too much...it's probably only your engine pistons! No big deal!
Old Apr 15, 2002 | 12:25 AM
mbtech208's Avatar
What?
