Airbag Warning light has come on
Old Apr 21, 2021 | 04:27 PM
Mercnotworking's Avatar
CLK 230 Convertible 1999
Hi,
After a winter of tinkering with the car, I have put the car back together again and everything works apart from 2 things.
1. SRS Light has come on.
2. The Heated seats don't work.
The drivers side door was replaced.
I took the passenger seat and the drivers seat out and tried to fix the squeek in the passenger seat by taking it to bits.
The battery was disconnected for weeks.
2 high powered mechanics have tried to clear the code and failed.
Is there something in the seat that could stop the Airbag from working?
Thanks in advance
Old Apr 21, 2021 | 06:37 PM
Serndipity's Avatar
2001 CLK320 Cabrio
If the SRS system is fully functional, the SRS MIL (instrument cluster malfunction light) should turn off after 4 seconds.
Does your SRS MIL thereafter turn off after 2 minutes?
Old Apr 22, 2021 | 01:20 PM
convicted's Avatar
1998 CLK 320
Hang tight. It could be something as simple as the SRS plug. When you put the seats back together, did you make sure you plugged in all applicable harnesses (properly)? If the SRS sensor in the seat can't tell if there is weight on the passenger seat, it will throw a code every time. Check the easiest things first.
Old Apr 22, 2021 | 01:21 PM
convicted's Avatar
1998 CLK 320
Originally Posted by Plutoe
the only real way to determine the real story is to get a DAS scan. All else sell the car
Hey there! I spent more than 30 years in Tampa. I just noticed that.
Old Apr 22, 2021 | 05:03 PM
Sadly, the SRS light stays on.
Old Apr 22, 2021 | 05:34 PM
That's a really good idea. I'll do that first before I take the door to bits to check for (self-inflected) damage to the wiring loom.
Old Apr 22, 2021 | 05:36 PM
I ain't givng up just yet, even if it means leaving it off the road all summer.
Old Apr 23, 2021 | 12:41 PM
convicted's Avatar
1998 CLK 320
Don't worry my friend. You have plenty of good people here that want to see you succeed. We'll get it figured out.
Old Apr 23, 2021 | 03:29 PM
Thanks to all for comments. You guys are great.
