Weird stutter when hot
Old Mar 12, 2025 | 12:49 AM
ImperialTech's Avatar
2002 CLK 430, 2007 C230
I've seen a few people with this issue over the forum, but cannot for the life of me find any resolution.
I have a 02' CLK 430, coming up on 83k miles. When the car in in gear, idling on a hot day, the engine will sometimes drop RPMs like it wants to shut off, then rebound as if nothing happened. Then occasionally if sitting again in traffic if I attempt to accelerate, there will be a stutter that feels like the car wants to shut off very briefly, then kicks off like nothing is wrong. This will occur once a blue moon, and has no rhyme or reason when it occurs other than during hot days (I can sit idle in traffic all day long during colder months, and it will never happen). It is very unreplaceable, and despite my best attempts, I can literally never get it to occur when I'm trying to diagnose the issue.
I have no check engine light, and the car normally runs like silk save for this occurrence in hot weather while idling. The car has never even came close to overheating either, so cooling is not an issue as far as I can tell.
Things I have done:
Regular Oil Changes
Replaced Mass Air Flow Filter
Replace Sparks
Replaced Air Filter
I've seen the CPS and Throttle Body come up a few times, but people have ranged from saying that's not it, to "just hook it up to a star computer." Any advice will be appreciated.
Old Mar 12, 2025 | 12:57 AM
unlukky's Avatar
2019 CLS450/ 2002 CLK55
Mass air flow filter? You mean you change the screen in the front of the Mass air flow sensor or the intake filters for the engine? Or did you change the mass air flow sensor entirely? Did you use an OE Bosch unit? The knock offs tend to fail.
Could be a crankshaft position sensor starting to go, fuel filter, or maybe even a vacuum leak?
I'd clean the MAF sensor and throttle body, change the fuel filter (if you haven't), and check for leaks.
John
Old Mar 12, 2025 | 01:00 AM
I did say filter hastily typing by mistake, I meant the entire sensor, put in a OEM Bosch. Haven't checked for leaks, planning on doing fuel filter probably near the end of this month.
Old Mar 12, 2025 | 05:02 AM
andy_breuer's Avatar
CLK 430
I’ve got a CLK 430 and had a similar issue, and have been able to resolve it. Mine would stumble more regularly and eventually the check engine light would come on with a “lean on bank 1” error. The stumbling was actually the timing getting retarded, due to a perceived timing knock. I was able to resolve by replacing the knock sensors and intake manifold gaskets. The service takes 2-3 hours and about $40 in parts. Your light doesn’t come on likely because it isn’t happening often enough to trigger, but will likely in the future if this is the issue.
Old Mar 12, 2025 | 05:04 AM
CLK 430
Also, the OBD2 holds temporary errors (your stumbles) so get a cheap OBD2 reader and plug it in after a stumble happens to see what may have been recorded.
Old Mar 12, 2025 | 01:11 PM
Was yours also doing this predominately when hot? I've checked my car multiple times to see if I could find a code anywhere stored and no luck. I have a Foxwell scan computer and did find a stored code for p0455 for evap leak (which is something I will have to take a look at now). Don't know if anyone has had similar issues with that particular code.
Old Mar 12, 2025 | 01:31 PM
CLK 430
I’m not sure if it was predominantly hot. It was usually 5-10 minutes after startup that it would register.
Old Mar 12, 2025 | 11:33 PM
unlukky's Avatar
When you change the fuel filter make sure you get the Mahle filter. I used a no name autozone brand and it caused howl at the hose from the pump to the filter. Yes, you read it right. Several others have had similar issues, so make sure you get the Mahle.
https://www.autohausaz.com/pn/002477...YaApD9EALw_wcB
John
Old Sep 17, 2025 | 02:52 PM
So I hate to necropost but did want to say I finally figured out the problem. Changed out literally everything that seemed could be an issue, new filter, changed MAF, plugs etc.
It was the accelerator position sensor going bad combined with a failing TPS that just hadn't given up the ghost yet. Anyone who encounters this problem is advise checking your accelerator position sensor as your car will not throw a code for it more than likely, but it may leave a pending code as what it finally did with mines.
