steering wheel
Old 07-28-2009, 03:32 PM
dnguy344's Avatar
clk500
steering wheel
anyone knows how hard is it to change out the steering wheel? can it be done at home or i have to take it to the shop? please help...thanks
Old 07-28-2009, 03:37 PM
BennyzGirl's Avatar
2004 CLK 500
How about more info on what you want to change it out for? You will have to worry about the airbag system, wiring and so forth.
Old 07-28-2009, 03:46 PM
dnguy344's Avatar
clk500
take out the leather steering wheel i have now and replace it with a wooden one
Old 07-28-2009, 05:20 PM
moondust's Avatar
2004 CLK 240
I haven't done one - but reading the WIS, it should not be too difficult. As stated you will need to take care with the airbag, and also you will need some force to remove the center nut holding the wheel. There is a torque value when re-fitting the new wheel.
Add some details about your model & location with the UserCP ^^^ and I''ll put some diagrams up here.
Old 07-29-2009, 09:14 AM
dnguy344's Avatar
clk500
i have a 2005 clk500 and i'm in the US...thanks
Old 07-29-2009, 10:46 AM
jsr
jsr's Avatar
Check out this write-up for swapping the steering wheel on a W210. All modern Mercedes have a pretty similar setup.
https://mbworld.org/forums/e-class-w...step-pics.html
Old 07-29-2009, 11:30 AM
moondust's Avatar
2004 CLK 240
a) removing the airbag
OK - here goes. I'll post in 2 stages:
b) removing the steering wheel
Read all the instructions - not all apply to your W209. Also, I do not always disconnect the battery when the WIS advises. In this case I think that I would - even though you then have to 'normalise' windows, steering, sunroof, etc, when you re-connect it.
Note the torque for the steering wheel nut. The 2 bolts under the wheel holding the airbag are torx type.
Attached Thumbnails steering wheel-w209-airbag1.jpg   steering wheel-w209-airbag2.jpg   steering wheel-w209-airbag3.jpg
Old 07-29-2009, 11:42 AM
moondust's Avatar
2004 CLK 240
You may need some assistance to remove the center nut, while holding the steering wheel steady.
Attached Thumbnails steering wheel-w209-sw-1.jpg   steering wheel-w209-sw-2.jpg   steering wheel-w209-sw-3.jpg   steering wheel-w209-sw-4.jpg   steering wheel-w209-sw-5.jpg
Old 07-29-2009, 10:11 PM
CLK5OO's Avatar
'06 CLK500 '10 C63
Check out over on benzworld the complete step by step I did on removing and installing a steering wheel on a W209 CLK. Lists everything you will need to know with some photos too.
Dave
Old 07-30-2009, 11:56 AM
dnguy344's Avatar
clk500
thanks for your help guys
Old 07-30-2009, 01:28 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I swapped mine out about a year ago, it wasn't too hard! It took about 20-30 min and I did need someone else to help me while taking out center screw. Just make sure car is off before unplugging airbag. Some people go as far as disconnecting the battery but I didn't.
Old 08-04-2009, 11:45 PM
BLKCLK350's Avatar
06 CLK350
i just picked up a new woodgrain wheel to replace the leather one in my 06 clk350 today off ebay for $399 shipped!!!! it was from a salvaged shop perfect condition. This will def help w/ the install, thanks!!!!
Old 08-05-2009, 02:02 AM
Flame3g's Avatar
CLK500 SPORT
Thanks guys i plan on buying one from dctms...the more aggresive one
Old 08-07-2009, 09:23 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Post some pics when your done!!
Old 08-07-2009, 11:11 PM
CLK5OO's Avatar
'06 CLK500 '10 C63
Ok I uploaded some pics of what to expect when you pull the wheel in a W209. I swapped from a button equipped wheel to a paddle equipped wheel. The pics should be pretty self explanatory. Notice the small holes on the back side of the wheel. this is there the torx bolts are that release the airbag. You will need a T shaped torx to get these out easily. Also a big honkin Allen head to remove the wheel itself. If you are swapping a wheel with buttons its easy. If you want to add paddles or buttons and did not have them good luck!. The silver bar on the right side of the inside of the wheel is where all the controls for electronics plug in. DO NOT remove the clock spring under the wheel. I also did not pull the battery. As long as the key is not in the ignition the air bag won't fire. Plese see my extensive writeup on benzworld for step by step installation including a tool list etc. The wheel i put in is a factory AMG wheel with Alcantara. It is super nice and I got it brand new shipped from Sweeden for about $400 something. A fantastic deal at the time. The guy sells this wheel today for 699 plus 60 shipping.
Attached Thumbnails steering wheel-p1020551.jpg   steering wheel-p1020545.jpg   steering wheel-p1020547.jpg   steering wheel-p1020548.jpg   steering wheel-p1020549.jpg
Old 08-14-2009, 09:19 AM
rwnevinger's Avatar
Remove 2 Torx 27 or 30 screws behind the wheel. (can't remember the size) make sure key is off. Disconnect airbag (yellow and green) connectors, and 3 pin harness. Use a Hex 10mm to remove the center bolt. Remove wheel. Replace wheel.
Old 01-17-2022, 06:30 PM
Olivier CLK500's Avatar
2005 CLK500 - 2013 GL550
2005 CLK500 Steering wheel issue
Hi,
My 2005 CLK500 start a while ago to gitch on the steering wheel gear pedals buttons. Some days it works and then it goes out and then comes back. Now, it doesn't come back and in addition, I lost all functions on the steering wheel as horn, volume, menu functions...
Some little garage told me that was the multi-function steering wheel issue and the part 230-460-05-03-9E37 must be replaced. Does anybody know if this makes sense or it is more the Steering Column Switches Clock?
Thank you.
Old 01-17-2022, 06:34 PM
Hi,
Thank you.
Old 01-18-2022, 12:26 PM
dzmitry's Avatar
2023 E450 AT, 1996 S420, (sold) 2004 CLK320 Convertible (v8, 6 speed)
My first ques would be that you have bad clock spring.
Anyway the cheapest option is to remove steering wheel and check switches with a multimeter.
Old 01-18-2022, 05:22 PM
Thumbs up
You are right, the Steering Column Switches Clock is cheaper so I will check it with a multimeter first.
Thank you for your advice.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
Quick Reply: steering wheel
