how to remove door sills
Lower the window.
Remove the cover that holds the tweeter and unplug.
Remove the plastic panel that surrounds the door latch - 1 screw
Remove the chrome plate above the latch at the top of the door - 3 screws.
Remove the 2 T30 torx screws; One behind the SRS airbag badge and one behind a plastic cover just under the door handle (my cover was a bit difficult to get off).
Once you have removed these screws carefully pull the door card from the bottom to unclip the plastic poppers. There are 4 of them along the bottom and up 2 each side. You may need to use a plastic wedge to help pop the card away from the door.
Once the poppers are all free, lift the card sharply upwards using the door handle. This unhooks the card from the door.
Once unhooked, the card is now only held in by the rubber window strip. Carefully pull the card out of the rubber strip starting from one side. Sometimes the whole rubber strip comes away from the door. If this happens then you must remove the strip from the door card before proceeding any further.
The last step is to remove the door lever cable by pulling back the cable to free from the mounting and then unhook from the lever. Then disconnect the window switch (slide the white tab) and then lastly remove the bottom light by removing the surround before disconnecting it.
The card is now free from the car.
Note the plastic surround you removed from the door latch is used to press the door switch and without this, the window will not close completely when the door is shut. The car will think the door is always open until this is refitted.
Just to be sure, with pix...
What you just explainted is the same procedure
as this thread? LINK Window rattling ?
Could of done with those pics when i did the job but too late now.
Ironically the reason i needed to take my door card off was because the passenger window was ratlling when the window was down. Shutting the door produced that crashing feeling you only get with jap cars.
The reason was because there was a missing bolt from the top RH mount and the LH mount which is also the fore/aft adjuster was loose.
The bottom bolts were fine.
Is there a Merc procedure for setting the window position up ? My passenger window sits further out at the top than the drivers side when the door is closed. I adjusted the bottom mount but its on maximum tilt.
Lower the window.
plastic cover with both hands (on the inside) and pull up hard. The
cover is held in place by the brackets marked with the red circles.
