What wheels are these?
Old Jan 8, 2010 | 02:27 AM
rennwerkes's Avatar
2001 E55, 2002 ML55, 2002 SL500, 2003 CLK55
Can anyone identify these wheels?
Wondering if they'll fit a CLK.
Owner says they're from a 2005 E500 but I don't think so.
Old Jan 8, 2010 | 03:09 AM
WPOZZZ's Avatar
W211 E55, 911 turbo, 911sc, RX330
gnma's E500
Old Jan 8, 2010 | 09:14 AM
kevblah's Avatar
E90 M3
not sure what car they're from, but definitely not from an 05 e500
Old Jan 8, 2010 | 12:00 PM
M-bENZ's Avatar
Corrolla
those wheel came from CLK500 03 04.
Andy
Old Jan 8, 2010 | 01:23 PM
rennwerkes's Avatar
Thanks for the responses.
I wonder if they'll fit my 03 CLK?
The interesting thing is that this set, I'm being told, are 8's and 9's X 18's with an offset of 30 and 39 respectively.
Old Jan 8, 2010 | 03:21 PM
M-bENZ's Avatar
Corrolla
if it really came off from CLK500 you wont have any problem with your CLK320. Are those OEM or knock offs ? Check the wheels first before you buy it.
Andy
Old Jan 8, 2010 | 05:23 PM
WPOZZZ's Avatar
Andy
My CLK500 had 17s, not 18s.
Old Jan 9, 2010 | 07:59 AM
FastDonzi's Avatar
'10 c63,'03expedition,ducati999,22'Donzi
Is your clk lowered? if not,they should fit, but you might need a small spacer in the rear. my friend was leasing an e500 with the sport package and it had those wheels on it. i don't remember what year it was though.GL
Old Jan 9, 2010 | 01:23 PM
rennwerkes's Avatar
No, I don't plan on lowering it. It'll be my wife's daily driver. Just needed wheels that would fit better than the ones I have on right now and also better quality.
I think I've determined that these wheels are indeed are from a W211.
Old Jan 9, 2010 | 02:36 PM
M-bENZ's Avatar
Corrolla
it depends on on the first owner of the car they upgraded or not. One of my buddy jsut bought the same car CLK500. He got 18" likes my current wheels.
Andy
Old Jan 9, 2010 | 03:46 PM
AMGDriver's Avatar
1999 C43 White on Black/White, 1999 CLK430, 2004 CLK500
could also be from a SL55 2003ish....
Old Jan 9, 2010 | 06:09 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
yeah if they're 18's they're not from a clk. but they might fit.
Old Jan 12, 2010 | 07:07 PM
v12's Avatar
v12
clk270 cdi
These wheels are definitely from a W211 e-class, no other car runs those offsets on those size wheels.
They will not fit your W209 without spacers on the back. Even at standard ride height.
The SL wheels have a much lower offset than these.
Old Jan 12, 2010 | 07:29 PM
rennwerkes's Avatar
Scary the amount of misinformation when it comes to wheels.
I think you're right about the rear. Seems as though it's about 5mm too tight. Would you suggest 5mm spacers? If so, what's the general consensus of who to buy them from?
Old Jan 12, 2010 | 07:51 PM
v12's Avatar
v12
clk270 cdi
I also forgot to mention that the W211 uses M14 wheel bolts, as opposed to the M12 bolts used in our W209's.
It is posible to get hold of adapter bolts, but they're almost impossible to get hold of.
I'm in the UK myself and there is only one supplier of the right type of bolt, with M12 thread, but with a M14 head to seat in the wheel correctly.
Here are the wheels you have pictured:
http://www.alloywheelsdirect.net/mer..._iii_wheel_681
Here are the CLK equivalents :
http://www.alloywheelsdirect.net/mer..._iii_wheel_429
You can see the CLK wheels are half an inch slimmer than the W211 wheels.
For reference, these are the SL wheels, which do fit straight on without spacers and are wider than the W211 wheels.
http://www.alloywheelsdirect.net/mer..._iii_wheel_117
The site i link to can be taken as gospel, he is a specialist about 15 miles from me and the only importer of the adapter bolts i referred to earlier.
I think the moral of the story is, avoid these wheels unless you get them DIRT cheap, then it may be worth getting spacers and adapter bolts...
Old Jan 12, 2010 | 08:12 PM
rennwerkes's Avatar
Well, I'm stuck with these wheels since I thought from the earlier posts that the wheels would fit.
I'm guessing a 5mm spacer would do the trick but I've never heard about the different bolt head. I thought all Mercedes lug nuts used the same conical seat??? And s**t, I didn't even know they used different threading! What's up with that??!
Old Jan 13, 2010 | 03:55 AM
v12's Avatar
v12
clk270 cdi
Theoretically a 5mm spacer should work for you on the back.
Best to get friendly with a local tyre shop and try some 5mm out and make sure the wheel sits fine.
The bolt issue catches a lot of people out.
The usual M12 bolts from your car should hold the wheels on, but the conical "flange" part of the bolt is smaller on your bolts than should be used for the wheel, hence making the running of the wheels with your bolts unsafe.
If you try one of your bolts in one of the wheels you'll see what i mean, you really need the bigger bolts with the M14 radius seat to fit the wheels properly.
Mercedes use M14 threaded bolts on all s-classes, e-classes from 2003, v-class's, ML's and GL's...Would have been nice if they had kept to a single standard!
Old Jan 13, 2010 | 04:00 AM
rennwerkes's Avatar
Should I be okay using the CLK wheel bolts if only using as a daily driver?
I'm starting to worry!
Old Jan 13, 2010 | 04:40 AM
v12's Avatar
v12
clk270 cdi
I wouldn't, especially for the safety of my wife and family...A wheel coming off at only 30mph could be a major disaster if she was going round a corner which is when it's likely to break off.
Old Jan 13, 2010 | 04:41 AM
v12's Avatar
v12
clk270 cdi
Sorry to give you such a pessimistic view on the subject, but compromising safety on something like this really isn't worth saving myself a few $$'s
Old Jan 13, 2010 | 03:18 PM
rennwerkes's Avatar
Thanks for the advice.
But I'm still
Old Jan 14, 2010 | 01:21 AM
lowpost's Avatar
damn that sucks that you bought them cuz of the earlier posts here - good luck. Try and sell them.
Old Feb 15, 2010 | 04:26 PM
rennwerkes's Avatar
Here's a update to this thread.
I'm guessing there are quite a few folks running E211 wheels or similar on their W210 or W209 cars.
I even called Ronal (the OEM manufacturer for Mercedes wheels) and was told to not use the M12 bolts on and an M14 wheel.
Apparently this company sources the correct bolts for a very reasonable price.
radusadirect.com
