18" Wheels on a CLK320 dont fit! Please help
Old Apr 8, 2010 | 04:48 PM
KingTUT's Avatar
CLK320
Question 18" Wheels on a CLK320 dont fit! Please help
Hi guys,
This is my very first post, and I am hoping some of you can help me out. I own a 2004 CLK320 and just picked up a nice set of 18" AMG rims and Pirelli P Zero tires. I was almost certain that they would fit on my car but my mechanic said they are too big and wont fit. Please help, did I buy the wrong size rims? how can I make this work? Here are the specs:
Rims:
Front: 18" x 8.5"
Rear: 18" x 9.5"
5 x 112 bolt patern
30mm offset
Tires:
Pirelli P-zero tires
Front: P235/40ZR18
Rear: P255/35ZR18
Thanks so much guys. I look forward to your response.
Old Apr 8, 2010 | 04:59 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Originally Posted by KingTUT
Hi guys,
Rims:
Front: 18" x 8.5"
Rear: 18" x 9.5"
5 x 112 bolt patern
30mm offset
Tires:
Front: P235/40ZR18
Rear: P255/35ZR18
Welcome
Now, please search.
Rims and their offset as well as tires sizes have been covered numerous times.
Old Apr 8, 2010 | 05:04 PM
BadDebt's Avatar
2008 ML550 P2. 2010 E350 P2
What exactly did the Mechanic say? I am no expert on the wheels but the specs you gave seems okay to me?
Old Apr 8, 2010 | 05:06 PM
KingTUT's Avatar
CLK320
The mechanic said that the wheels were touching the shock and there wasn't much space between them and the fender. As far as I know my car was never lowered so not sure why this is the case. I am going to try to take it to the Mercedes dealer tomorrow and have them take a look.
Old Apr 8, 2010 | 05:09 PM
KingTUT's Avatar
CLK320
Originally Posted by amdeutsch
Welcome
Now, please search.
I already tired searching. I would have thought someone with 11,000+ posts like you would have a more knowledgeable answer for me, that's why I joined the forum.
Does anyone else know what could be the problem? Is it the offset?
Old Apr 8, 2010 | 05:15 PM
BadDebt's Avatar
I am pretty sure OEM offset is 30mm
Old Apr 8, 2010 | 06:09 PM
Rashman's Avatar
Mercedes-Benz CLK63 AMG Coupe
Sounds like it could be the offset that's causing the issue.
I always thought they gave the fronts an offset of 35?
Or maybe the mechanic is just playing it safe.
I have 19" rims, 8.5" wide at the front with a 35 offset.
I don't have any problems and I reckon I still have alittle more room to play with.
Old Apr 8, 2010 | 08:27 PM
coin's Avatar
'06 CLK500
Go to another mechanic. They should fit fine
Old Apr 8, 2010 | 09:30 PM
henry47's Avatar
asdf
i agree. from what you've written, the specs look like they would fit
Old Apr 9, 2010 | 08:11 AM
i_am_amused's Avatar
2004 S55 (SOLD, miss it every day), 2009 GL550
Welcome
Now, please search.
i don't know which is funnier, the mod or the sad reply
Old Apr 9, 2010 | 10:35 AM
KingTUT's Avatar
CLK320
Guys i got some bad news... I took the rims to the dealer this morning and they said the wheels are too big for the car? What are the specs on the rims for those of you who got 18" wheels on your cars? By the way the offset for the front is 35mm i just double checked. Also I went to another shop and they told me the 235 tires in the front are too big i need 225's.
What is going on??? Is anyone in the Boston area that can recommend a mechanic that knows how to make this work? I would understand if I had the wrong size wheels/tires but so far it seems like I have the right sizes and they should fit on my car.
Old Apr 9, 2010 | 11:00 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Running a search for 235 turned up these links plus more
https://mbworld.org/forums/clk-class...tire-size.html
https://mbworld.org/forums/clk-class...ire-width.html
https://mbworld.org/forums/clk-class...ap-please.html
https://mbworld.org/forums/clk-class...-fit-w209.html
Old Apr 9, 2010 | 11:42 AM
KingTUT's Avatar
CLK320
Thanks Dynomite, what size wheels are on your CLK? Are those 18"?
Old Apr 9, 2010 | 12:01 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Nope 17's with 225/45/17 F and 245/40/17 R lowered
Old Apr 9, 2010 | 02:07 PM
astropat's Avatar
CLK 320
At stock monster truck 4x4 height, by those specs it seems like your wheels should be fine. I really don't know how the shoulder of your tires are, but there should be plenty of room. In the worst case, you can probably get some spacers to lower the offset and push the wheels toward the fender. I really can't imagine these wheels not fitting if your car hasn't been lowered.
Old Jul 16, 2018 | 08:42 AM
Steve G's Avatar
i own a mercedes clk 240 2004 model
hi mate i have a big problem
i own a mercedes 240 clk 04 model i bout a set of aftermarket monoblock wheels from america is there anyway i can make them fit
Old Jul 16, 2018 | 02:48 PM
Fatz's Avatar
2008 clk550 - Navigator - Frontier
What is it about them that does not fit? Do they rub the wheel well or the struts/shocks? Do the bolts not align? Are they rubbing the brake calipers? Are they a staggered wheel set? What size are the wheels and tires? Did the company you purchased them from say they would fit?
