radio buttons sticking together; is it safe to spray WD40?
Old May 3, 2010 | 01:55 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
My 4 and 7 buttons stick together a lot of the time
I tried to get it taken care of under warranty but my SA says that it was caused by liquid damage (someone must've used that dash mounted cupholder before I bought it!) Think it's safe to spray some WD40 in there?
Old May 3, 2010 | 02:04 PM
supacrazykev's Avatar
GLE 450 2021, SLK 350 2013, Honda Civc Type R 2019, Suzuki GSXR 750 2014, Ducati Diavel 2018
good question.. i want to know too. I accidentally spilled Monster
Old May 3, 2010 | 04:28 PM
mtrevelino's Avatar
2006 E320 CDI
I would try some electrical contact cleaner first. The electrical stuff will dry after a few seconds where the wd-40 will stay wet, not a good thing with electronics!
With my motorcycle, my horn button was sticking, a couple of hits with the electrical contact cleaner did the trick.
Mike T.
Old May 3, 2010 | 04:32 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Mike T.
+1
Old May 3, 2010 | 05:13 PM
idouoooo's Avatar
2005 CLK500 Cabriolet 2004 Maserati GT Coupe 2004 BMW 328cic
Nooooooooooooooooo... DO NOT SPRAY WD40!! It will ruin the finish on the face plate. Been there done that and learned the hard way. Not sure about the insides..Whatever you end up spraying in there make sure the radio has no power and leave it like that for a few hours for the substance to dry.
Old May 3, 2010 | 05:34 PM
M-bENZ's Avatar
Corrolla
CRC maybe ? I used this to clean my MAF sensor...it is fast drying. They are good for electronic but dont blame me if anything happen .
Andy
Attached Thumbnails radio buttons sticking together; is it safe to spray WD40?-11-21-09_1345.jpg
Old May 3, 2010 | 06:03 PM
eddieo45's Avatar
Andy
do you get much more life out a MAF after cleaning? I always wondered, especially back when I had a W202.
Old May 3, 2010 | 06:04 PM
eddieo45's Avatar
I think I'll try a dry toothbrush first, then maybe some canned air.
Old May 3, 2010 | 09:19 PM
M-bENZ's Avatar
Corrolla
not sure how long it will last but I had it cleaned when I first bought the car until now....not a single problem lolz. Did I mentioned I used that to clean my CLK320 MAF sensor too ?
Andy
Old May 3, 2010 | 09:26 PM
eddieo45's Avatar
I heard about cleaning MAFs, but was told that it wouldn't give me many more miles. I bought a MAF on eBay that only lasted 6 months so I ended up buying a new one, all this for my old 202. I've been lucky not to need one since. I assume you had a CEL code B4 cleaning; how long since?
Old May 3, 2010 | 09:59 PM
mikekuriger's Avatar
2010 C63
i would think that electronics cleaner is your best bet, although it may ruin the plastic. me personally, I'd just use plain old water.
Old May 3, 2010 | 11:58 PM
henry47's Avatar
asdf
i had this same problem when I spilled juice on my radio. what I did was just took a damp cloth and periodically kept wiping the buttons. eventually the water would slightly seep between the buttons and dilute it enough that the stickiness eventually went away.
Old May 4, 2010 | 02:06 PM
M-bENZ's Avatar
Corrolla
no no no CEL no mesage no nothing...just want to cleane before it gets dirty thats all. I have cleaned my CLK500 MAF with CRC for almost 4 months now and so far no complaint yet. The 320 MAF had it cleaned since day 1 until I traded in for like 3 years not a single problem. ALot of ppl using that but im not sure that you can clean with your radio buttons or not .
Andy
