Yes another dual exhaust question
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
I've been reading and reading non stop on converting my single exhaust on my 2004 clk 500 coupe to a dual exhaust...the route I've been thinking about going is getting another oem exhaust, cut the hole, wrap around the spare tire well and bore into the original exhaust...it would look stock and look great...
Ps I'm also gonna get my resonator removed...
Will this work?
Should I just have a fake side on the right or actually still link it to the left like I'm thinking?
Where can I find another oem exhaust?...
What is this plastic piece I keep reading about to get for 160?
And how is the camaro exhaust people have been getting?...
Thanks as always guys...
Will this work?
1 Post
W209, E46 M3 (dead), S54 swapped E46 Touring
C55 SPARE TIRE WELL 20368054429f08
will give you the extra room needed for the rear passenger side exit. i will be doing my exhaust again sometime in the next couple of months. ordering the C55 spare tire well, bs sway bars and still looking for the mufflers i plan to use.
i dont know what sound you are looking for but i wasnt that happy and i've heard the same from other members with the resonator removal. i can kind of tell the difference with high flow cats and removed resonator but i want something a lil deeper.
Will this work?
Will this work?
04 CLK 320 > CLK32K
Will this work?
Will this work?
The plastic piece for 160 that you're hearing about is a bit that attaches to the bottom of the bumper. Not sure about on the 500, but I assume it's the same as the 350 and it won't work. This piece is on the AMG bumpers, and on newer cars. I think like, 08-09 or
newer.
newer.
Jones is correct in that another exhaust won't fit on the right side without the spare well/BS sway swap. You have a couple options. Since your removing your resonator you could place a muffler in it's place and run one pipe to each side with 2 tips on the end. You could also do the wrap behind or in front of the spare tire well using a single/dual exhaust. The pic below shows the install with the Magnaflow Camaro exhaust. Check out this thread, there is a lot of part #'s for tips you could use https://mbworld.org/forums/clk-class...ts-part-s.html
You probably would. I haven't thought that far ahead yet. lol. I'm ordering the C55 well very soon so I will find out.
This piece is actually from the 05 CLK55 that came with quad from the factory. It should fit the AMG rear bumpers.
[QUOTE=dynomite05;4213062]Jones is correct in that another exhaust won't fit on the right side without the spare well/BS sway swap. You have a couple options. Since your removing your resonator you could place a muffler in it's place and run one pipe to each side with 2 tips on the end. You could also do the wrap behind or in front of the spare tire well using a single/dual exhaust. The pic below shows the install with the Magnaflow Camaro exhaust. Check out this thread, there is a lot of part #'s for tips you could use https://mbworld.org/forums/clk-class...ts-part-s.html
that's exactly what i wanted to do which was to get another oem clk 500 exhaust and run the piping around the spare tire well and into the original exhaust....
would this work?
any power loss?
anything parts i'm missing or would need?
where can i get another oem clk 500 exhaust with tip
would this work?
any power loss?
also anyone in the world have a picture of this "piece"? lol...i can't find it to save my life or really what it does...seems so simple to just cut the bumper and weld on some exhaust hangers...
04 CLK 320 > CLK32K
[QUOTE=Newjd2;4213115]
would this work?
any power loss?
would this work?
any power loss?
I posted the pic in my post above. It's the one of the CLK 55. You see the plastic black piece on the rear bumper on top of the tips.
04 CLK 320 > CLK32K
http://cgi.ebay.com/ebaymotors/2003-...#ht_1111wt_847
http://cgi.ebay.com/ebaymotors/03-05...ht_8870wt_1072
http://cgi.ebay.com/ebaymotors/MERCE...#ht_500wt_1089
http://cgi.ebay.com/ebaymotors/Merce...s#ht_500wt_864
http://cgi.ebay.com/ebaymotors/2003-...#ht_1762wt_847
hmmm...what do you think is the best option then cause replacing the tire well and back sway bars would be hell...
i'll probably go aftermarket considering the success people have been having with the camaro exhaust, but is there any other possible way of running it without replacing the tire well and sway bar?
also, i already have that plastic piece. i didn't know it was just needed for cars without the amg package.
also how's the sale on those springs going cause i'm still looking to buy a set of h&r sport springs...
thanks man...
thanks man...
and i was planning on getting something like this...running extra piping into the current exhaust and call it a day...but how to get past that tire well and sway bar now?...fake exhaust=lame...
http://cgi.ebay.com/ebaymotors/W209-...#ht_500wt_1182
04 CLK 320 > CLK32K
thanks man...
thanks man...
If you don't replace the spare tire well and the sway bar there is no way to fit 2 mufflers. You would have to put one muffler on the left (stock or aftermarket) and then link to the right with just the tips. Like the pic posted above going around the spare tire well.
i just plan on getting my amg bumper cut by a body shop...but now how do i go about replacing my tire well and replacing the sway bar?...mercedes just couldn't have done it stock for us huh?...
and what we looking at for the springs with shipping and everything?...where you shipping from?...
04 CLK 320 > CLK32K
I am shipping from NJ. Shipping is around $35. Asking $150 for the springs.
You would have to buy the BS rear sway bar and the spare tire well and have a shop swap them for you. I list all the part #'s you need in the parts sticky. I wish MB did it for us, it would of saved me a lot of work.
And for 185 count me in...if you can get shipping any lower that'd be perfect...
04 CLK 320 > CLK32K
I would have to check on the shipping, what is your zip? Contact H&R and make sure they fit because I believe their website lists a different part number for the 500.
I don't remember exactly how much I paid for the delete, I did a bunch of things at once. I haven't done the exhaust mod yet but it's next on my list. I have the BS sway bar installed and the tips sitting in my garage. I will be ordering the CF diffuser and the spare tire well in a few days. Once I have the well installed I will measure to see what size mufflers fit.
05 ML-500 , 03 CLK5.5 AMG has left the Garage
Here is what I Know the B/S Anti Sway bar
The B/S anti sway bar is 16 mm ,So you can use your OEM chassis mount rubber bushings. & It will bolt into the chassis mounts , But it will not bolt to the side links. The side arms of the B/S Anti sway bar, are straight with no bends, and are to long, (I've been working on adding in the bends & shorting the B/S anti sawy bar side arms) Please see attached pictures. In the pictures you will see how the bend from the stock bar, loops under the side thrust links. I'm still working on adding in more bend , to the B/S bar. I'm close
Cheers _PTEngineering
04 CLK 320 > CLK32K
My front and rear BS sways are installed already. i'm picking up the car on Monday. My mechanic said he had to mod the rear end links a bit. I will take some pics once I get it
