DIY: Remove and replace valve cover gaskets and spark plugs
Old Nov 10, 2013 | 12:11 AM
  #76
johnnr's Avatar
ML350 4Matic and CLK 430
Oil leak residue on valve cover?
In your pic...I see you mention oil build up on the valve cover, etc.
isn't that just normal carbon build up? From my experience, this doesn't indicate an oil leak...I've seen this build up on all engines I've worked on.
Just curious cause I have some build up on my CLK, but I don't believe there are any leaks.
Old Nov 10, 2013 | 08:44 PM
  #77
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You are correct, the build-up has nothing to do with leaks, but it should nonetheless be cleaned when replacing the gaskets. Especially the ports for the oil ventilation breathers.
Old Feb 3, 2014 | 03:59 AM
  #78
StevenHaywood's Avatar
1999 ML320, 2009 Cayenne GTS
Looks to me like the majority of that oil leak in the OP is seepage from the PCV chambers. Worth stripping those off and checking the tiny (1.5mm!!!!) hole isn't choked up. What a crap design!Also, +1 to no gasket sealant on the valve gasket - only on the vent chambers.
Old May 18, 2014 | 03:42 PM
  #79
PewterGreyBenz's Avatar
04 E500 Pewtergrey/ 06 E55 AMG White
I am getting ready to do this, so that smaller valve like cover on top of the valve covers are called breather covers?
Just want to be sure as I will pick up parts tomorrow from my local dealership
Also the one tube that you need to disconnect on the drivers side rear top of the valve cover, what is it called? It is sort of a hard plastic and wraps around towards the rear of the engine (black) Im afraid if i twist it, i will break it or should i just replace it? Thanks
Old May 19, 2014 | 11:18 PM
  #80
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That tube probably will break. There are actually two - one on each side. I'd go ahead and buy new ones. They are called "ventilation hoses"
A1120180382
A1120180182
There maybe a third one (on the driver's side). The dealer parts counter can look them up for you. If they have a hard time finding the parts diagram in EPC< tell them to look under "Engine" -> "Intake and Exhast Manifolds".
Old Sep 15, 2014 | 09:55 PM
  #81
Eojj's Avatar
W209(sold), W212, X204
Getting ready to do my valve covers and spark plugs! This is an awesome guide.. I'll be buying all the stuff for my mechanic to do this. Got a few questions:
1. Should I put anti seize on the spark plugs? What is a good brand to buy?
2. What kind of Gasket sealant should I buy for the small/breather covers?
3. Are there any safe products to clean the valve covers with?
Old Sep 15, 2014 | 10:58 PM
  #82
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
There is a "factory" part for the breather cover sealant, but it's basically black RTV. As for cleaning the covers, especially where you remove the old sealant on the breather covers, there is also a factory part for cleaning that, but again, it's just RTV solvent available at most auto parts stores. I used Gunk Engine Cleaner to clean up the grease. Microfiber cloths work great to remove any oil residue after soaking them in cleaner.
Old Sep 16, 2014 | 03:58 AM
  #83
tw2's Avatar
tw2
I don't. It will change the torque required which can cause over tightening and breaking things. I had no trouble removing what looked like the original spark plugs after 80,000 miles.
I cleaned all the sealant by hand, I didn't know there were solvents available It took ages!
Old Sep 16, 2014 | 06:14 PM
  #84
Eojj's Avatar
I guess something generic like this would work?
http://www.autozone.com/autozone/acc...er=554295_0_0_
I'm guessing it's fine to use, but is there any major issues if some of the gunk engine degreaser gets into the cylinder head? Or perhaps I should just use some good ol gasoline lol
Haha if I had the knowledge and time to do this job myself, I'd take my sweet time to make sure everything was squeaky clean. I'm buying all the materials for my mechanic to do it. That means his time is $$ .. In other words, if I buy him all the correct stuff he'll get it done more efficiently. Or he'll probably just use brake cleaner to clean the stuff lol
Old Sep 16, 2014 | 06:52 PM
  #85
tw2's Avatar
tw2
The odd drop of degreaser is not an issue. Having sealant get in there and potentially clogging up oil drains or the filter needs to be avoided.
Old Sep 17, 2014 | 12:02 AM
  #86
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
^ +1
You'll be cleaning the covers off the car, so there really shouldn't be much of a chance to have degreaser around the engine. And that is why I suggested a final clean-up with a microfiber cloth - those do a great job of removing residual oils. I buy bags of microfiber cloths from Costco. I wash them first, then use pristine cloths the remove wax, then after that, they become "shop towels".
Old Sep 18, 2014 | 01:07 PM
  #87
clkcadet's Avatar
S550
Nice write up- How do I tell if its time for new spark plugs?
I have 105k, but no mention of new spark plugs in my service paperwork.
Old Sep 18, 2014 | 11:04 PM
  #88
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Got to MBUSA.COM, and click "Owners". You can find your car's maintenance manual there and the spark plug change interval will be listed in it. I believe on your car, it's every 91K miles or 5 years, whichever comes first.
Old Sep 19, 2014 | 09:41 PM
  #89
M-Rods's Avatar
2013 C350 Previous: 2004 CLK 500, 2001 CLK 430
Since torque was mentioned....what is the torque specs for the sparks plugs?
Old Sep 19, 2014 | 10:17 PM
  #90
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
On the M113 engine, it's 25Nm
Old Sep 19, 2014 | 10:21 PM
  #91
M-Rods's Avatar
Perfect, plugs are on next months list.
Old Nov 15, 2014 | 03:47 PM
  #92
Wodeshed's Avatar
Current: 2020 E450 with self-driving capability
Right side of my CLK 320 at 145k miles:
Attached Thumbnails DIY:  Remove and replace valve cover gaskets and spark plugs-right-side.jpg
Old Nov 15, 2014 | 10:21 PM
  #93
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Looks pretty good! It's hard to tell from the photo, but if Mobil 1 0w40 was always used, everything should be a nice golden color.
Old Nov 16, 2014 | 04:33 PM
  #94
Wodeshed's Avatar
Thanks for the feedback. I can't speak to what was always used, since I've been a quickie oil change place guy until discovering this forum. I always had them use synthetic, but who knows what it was. Now that I'm back to DIY, I'm doing all Mobil 1 0w-40. At least it doesn't look all crudded up like that one I saw earlier on this thread.
Just finished valve cover & breather gasket on the right (passenger) side. Also replaced plugs (with Bosch Iridium, which were the same price as the platinum) and wires.
Elsewhere here I saw the post about cleaning the tiny hole through the breather cover leading to the right side breather hose. I used a wire on that since it was partially blocked, and also replaced that hose. No P0400 code yet, so maybe that was the solution.
Right side plugs were pretty rough. Most likely original equipment, and overdue for a change.
Old Nov 16, 2014 | 04:37 PM
  #95
Wodeshed's Avatar
Right side plugs at 145k miles:
Attached Thumbnails DIY:  Remove and replace valve cover gaskets and spark plugs-plugs.jpg
Old Nov 22, 2014 | 10:13 AM
  #96
Wodeshed's Avatar
Oh, one more observation; my oil fill neck would NOT pop off as suggested in the original post. I had to undo the passenger's side valve cover with the neck in place, then loosen the philips head screw on the interior side to remove.
Old Jan 2, 2015 | 12:51 AM
  #97
phoung's Avatar
'03 clk 500. WTB slk55
I thought that sealant is not needed since there is a gasket in place. On pelicanparts, they did not use a sealant.
Old Jan 2, 2015 | 01:34 AM
  #98
kennywong1234's Avatar
W209
No, do not use any sealant on the valve cover gaskets. However, the breather cover that is on top of the valve cover does not have a pre-formed gasket - you use black RTV on it. And you should remove it to clean it out along with cleaning the valve covers and the vacuum hose ports.
Hi Rudeney, may you please clarify, do we need any sealant while we reinstalling back the valve cover?
From the original post, it shown he put the sealant all around lol
Please kindly advice, thanks!
Old Jan 2, 2015 | 02:46 AM
  #99
tw2's Avatar
tw2
The gaskets seal the valve covers. Sealant seals the breather covers. You can't do one without the other.
Old Jan 2, 2015 | 03:27 AM
  #100
W209
I got it! thanks!
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
