W203 & W209 seats, interchangeable?
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Highly doubt if anyone knows the answer to this but thought I'd ask anyways - got some pretty bright cookies on this forum;
Does anyone know if the front seats are interchangeable (direct bolt in) between the C 203 and CLK 209?
If no one knows I'll pull one out of my C and try to fit it in my CLK when I get home.
I'm going to swap my interior out from light tan to black, I found a few written off CLK 350's in Dubai with black interior. However, I'm not going to use the factory front seats, I'm going to put in some leather Sparco seats and I see that they sell the seat brackets for a 203 C class but not a 209 CLK, I'm guessing they will probably work.
What I most likely will end up doing though is removing the bracket and a few motors off the factory CLK seats and mod the set up to fit on the Sparco set so I can retain the front/back & height adjustments.
We'll see, I'll be changing a bunch of other interior things in the process as well.
Yes, I actually thought about doing exactly that with the black seats but using alcantara for the colored inserts. But, I'm sure I'll go with the Sparco Milano Prestige as they are going to offer a whole lot of support and keep me planted in place on the track.
I'll let you know about the seat bracket after I test fit the C seat in the CLK this weekend.
2006 Facelift CLK500 Cab-
I would call them and see if someone that works there can send you measurements of how far the sliders/holes for seats/bottom mounting holes are apart. Maybe even send a pic of a direct overhead view of the bracket and then take one of your seats out and determine from there. You know give them the whole "I'm overseas and everything is so difficult and I'm just trying to find a helpful company to give some $$ to" routine. lol
Oh and I have some Neoprene Corbeau Moab's with sliding brackets in the jeep, I'm a big fan, but the neoprene is pretty easily torn. They have seen 2 topless Pensacola Beach summers though, so I can't really expect too much.
After I test fit my C seat in the CLK I'll know for sure if the bracket will work, if not, I'll make my own like I did for my Z34.
