spots on the lamp housing
Old Jan 6, 2011 | 08:28 PM
midnight AMG's Avatar
CLK 550
anyone ever get water marks inside their light housing??
Old Jan 6, 2011 | 08:30 PM
M-bENZ's Avatar
Corrolla
nope.
Andy
Old Jan 6, 2011 | 08:36 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Nope, no reason why that should happen. Check the seal on the light.
Old Jan 6, 2011 | 08:52 PM
Newjd2's Avatar
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
You have aftermarket headlights?...
Angelo
Old Jan 6, 2011 | 08:53 PM
M-bENZ's Avatar
Corrolla
lolz.
Andy
Old Jan 6, 2011 | 09:38 PM
sleepyheadzzz's Avatar
2000 Volvo S40, 2006 Hummer H3, 2008 CLK550
maybe little leprachauns got into your healight housing hahahaha
Old Jan 7, 2011 | 01:46 AM
thegeneraltso's Avatar
05 CLK500; 07 Volvo XC90
I get water vapor inside the housing if I parked it overnight outside when it is frosty.
Old Jan 7, 2011 | 03:25 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Inside? I have had condensation on the outside, but never inside. There has to be a seal going bad, no?
Old Jan 8, 2011 | 08:46 PM
Yup, condensation on the inside. Does not happen when driving in rain or automatic car wash. Not sure if the seal is bad. I am waiting to have enough monies to upgrade to HIDs
Old Jan 8, 2011 | 08:57 PM
Clkboi's Avatar
CLS550 4Matic
Angelo
as far as i know there is no after market headlights for the CLK w209 and C55 AMG
Old Jan 8, 2011 | 08:58 PM
Clkboi's Avatar
CLS550 4Matic
Originally Posted by M-bENZ
lolz.
Andy
Nice sig Andy the car is looking great i love it
Old Jan 8, 2011 | 10:08 PM
M-bENZ's Avatar
Corrolla
Thank you ...thank you .
Andy
Old Jan 11, 2011 | 01:48 AM
CLK 550
apparently im not the only one...
http://www.slkworld.com/slk-r171-gen...ight-lens.html
Old Jan 11, 2011 | 09:37 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Check to make sure that the bulb connector/asembly is correctly 'closed up'/sealed on the back of the headlight housing. If you're not getting any water in from the front side, you may be getting it in on the other. Vapor droplets are very small and dont need much room to find their way into a dry area.
Just an idea.
Old Jan 11, 2011 | 09:45 AM
Clkboi's Avatar
CLS550 4Matic
Are you using after market HID and if so assuming that you had to make a hole in your plastic cover make sure it's sealed!
Old Jan 12, 2011 | 01:14 AM
CLK 550
Nope no aftermarket hid
Only changed the parking bulbs and the factory d1s bulbs to 8000
K
Still a mystery .. My prob is exactly like that guys post on clk forums
Its not water vapor literally water spots all over the light housing (looks like dirty dish water)
Old Jan 12, 2011 | 01:42 AM
Kevwood's Avatar
Yes, but water vapor collects and forms drops, that's what you have right? It sure sound like its a very small opening to me considering the way nothing enters from the front in rain but it will when its cool and humid.
Old Jan 13, 2011 | 12:01 AM
CLK 550
All this happened after I got some body work done to my bumper at a body shop
They are claiming they had nothing to do with water leaking in except that my car was in the shop for 3 weeks..one of which was pretty much down pouring
Old Jan 13, 2011 | 01:09 AM
Kevwood's Avatar
Ah, here's what I think now - the moisture is sealed in there. When it was in the bodyshop and pouring they might have had the headlights off or the blubs out, the humid air got in & they put it all back together. Now when it's cold out the moist air fogs up.
On a cold day when there is very low humidity, pull the car in your garage, pop out the bulb, use a hairdryer to blow hot dry air into the housing until its nice and warm then seal it back up. If you have no leaks that should solve the problem as the humid air will have been dried out.
Old Jan 13, 2011 | 03:37 AM
CLK 550
Kevwood...thanks so much for your analysis..i believe that is a correct mechanism
However the spots of water have actually dried onto the lamp housing plastic itself
I actually brought the car back to the body shop where "this has happened to them before" from another car. So they did try to blow dry it... However since the condensation has already left spots... Not sure what to do next
Old Jan 15, 2011 | 05:13 AM
Kevwood's Avatar
Pop the bulbs out and use windex and twist-tied cotton swaps on the end of something like a pencil to reach inside the housing and clean it. I had a bulb shatter inside the housing of another car and did this to clean it all up (it was a major PIA to remove the housing).
