DIY Converting to center cup console
Old Jan 22, 2011 | 05:51 PM
tcapps2461's Avatar
clk 350 w209, shelby gt 500,bmw 330xi
This modification is for you guys who have the center compartment without the sliding tray and cup holders. If you can get a good used cup console it is better than buying the parts directly from the stealership.
1st: Disconnect positive battery terminal (We didn’t and it works fine)
2nd: Remove pad from bottom of console to expose 2 (10mm) bolts. (Just pulls out no clips)
3rd: Open front ashtray door. Then pop shifter trim out, pulling up from the front of the piece. Leave shifter knob on. (We had to pull hard)
4th: Disconnect wires from bottom of shifter trim.
5th: Remove ashtray by pulling up a little and towards back of car.
6th: Remove 2 (10mm) bolts from bottom of the compartment; remove the other 2 (10mm) bolts that are beneath the shifter trim.
7th: Remove the 2 torx that are behind where the ashtray was. Loosen locking torx on drivers side (Maybe on both sides)
---At this point the console is now loose.
1st: Open console lid and remove torx to gain access to wires. (Remove wires from lid)
2nd: Pop air conditioning trim off back. (Pull hard straight up to get top over lip) Bottom half pops straight back.
3rd: Unclip trim from top of storage compartment.
4th: Console lid assembly will slide up and out
---At this point console lid is now removed.
Old Jan 22, 2011 | 05:52 PM
tcapps2461's Avatar
1st: Remove 6 torx from console panel (I think they are T10 Red circles)
2nd: Remove panel trim from console. (This piece you may need to cut if you don’t have a donor console)
3rd Remove secret compartment (50), then remove plastic piece (80) Blue arrow
---Prepping time.
1st: Cut console piece so new compartment can fit.
2nd: Insert new rounded cross member from donor cup console.
3rd: Cut console trim panel so lid can click into future compartment. ( Refer to the end of the post for dimensions)
4th: Put console trim panel back on and secure. (Put 6 torxs back in)
5th: Re-secure console to floor.
6th: Clip side clips onto trim (Came with donor cup console)
7th: Feed wires up back of compartment into a wire troth.
8th: Insert new compartment into console. (Make sure wires stay to the back and beneath compartment)
9Th: Screw new compartment to new cross member.
10th: Secure air conditioning piece back onto console
11th: Insert ashtray; attach wires to shifter trim then clip shifter trim onto console.
12th: Clip new lid cover onto console.
Old Jan 22, 2011 | 05:53 PM
tcapps2461's Avatar
Unique parts to new console.
1st: Side clips as stated in prepping time #6.
2nd: Cross member as stated in prepping time #2.
3rd: Sliding tray cup assembly.
4th: Cut existing trim if you don’t have donor cup console.
If donor cup console isn’t correct color you can recolor it from Leather Magic. Color was perfect.
PM me for inquiring about getting a template or help if you’re in the tristate area.
---Finished product---
Old Jan 22, 2011 | 06:08 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Nice DIY! No I only have to find the piece in anthracite and I will be set. I don't think Anthracite was an option for facelift models.
Edit: You dyed the piece? What color was it originally?
Old Jan 22, 2011 | 06:12 PM
M-bENZ's Avatar
Corrolla
this $h*t is more complicated than i thought but hey at least your done with it . Nice write-up.
Andy
Old Jan 22, 2011 | 06:37 PM
tcapps2461's Avatar
anthracite.So it looks like I have one of the pieces, the one you would have to cut already cut from the factory
Old Jan 22, 2011 | 06:39 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
You willing to part with it? So I guess you did dye the cover.
Old Jan 22, 2011 | 07:32 PM
tcapps2461's Avatar
yes
Old Jan 22, 2011 | 08:12 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
PM your asking price shipped to 07657.
Old Jan 23, 2011 | 01:32 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Fantastic write up! Quality work, excellent color change!
Old Jan 23, 2011 | 02:10 AM
M-bENZ's Avatar
Corrolla
tcaps,
Do u have the cover on your steering wheel ? looks like it...
Andy
Old Jan 23, 2011 | 07:39 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
I guess he doesn't want to sell.
Old Jan 23, 2011 | 09:55 AM
tcapps2461's Avatar
About the steering wheel cover I would send the extra $700 or so dollars for the real thing the cover is junk
Old Jan 23, 2011 | 10:04 AM
tcapps2461's Avatar
I will sell it, I got caught up in the barrett jackson auction last night. Got stuck watching it until 1:00 am, who said the economy is bad,a lot of people spent a lot of money for cars that aren't worth a lot.
I will PM you with the price.
Old Jan 23, 2011 | 10:33 AM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Fantastic DYI (from a newbie non the less)! Thanks for contributing to the W209 community!
Old Jan 23, 2011 | 12:23 PM
thegeneraltso's Avatar
05 CLK500; 07 Volvo XC90
Awesome mod. A little too complicated for my meager skill. i wish we would get at least two cupholders. The engineer who came up with the location by the vent way from the driver should be flocked. A cold soda gets lukewarm after an hour trip in a toasty warm car
Old Jan 25, 2011 | 07:48 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Old Jan 27, 2011 | 09:16 PM
which year W209 does it have the cupholder? I cannot find the parts on part.com.
Old Jan 28, 2011 | 06:30 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
I have the part # at work, I will post later. I think it was going for $370 new through parts.com.
Old Jan 30, 2011 | 08:44 PM
It looks like you have to remove the entire center console out to add in the cup holder compartment. Do you know if I could just purchase the entire center console with the new cupholder compartment minus the wood trim from an '07+ and basically just do a swap?
Old Jan 30, 2011 | 08:59 PM
M-bENZ's Avatar
Corrolla
Good question . I want to know if I can do swap like that too .. Less headache .
Old Jan 31, 2011 | 03:24 PM
tcapps2461's Avatar
yes you can change the whole console with less headache, how ever your bank account will take a hit.There does not seem to be any used ones around, new is going to be lot of money
Old Jan 31, 2011 | 06:30 PM
M-bENZ's Avatar
Corrolla
I see.
Old Jan 31, 2011 | 06:58 PM
... how ever your bank account will take a hit ... new is going to be lot of money
Do you know how much we are talking? $300.00-$500.00? I might just do it because one cup holder on 'the other side' the dash is not doing it for me Of course unless someone can guide me toward an 'aftermarket' cupholder attached to the side of the console .
Old Jan 31, 2011 | 08:54 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I know the lid itself is around $375 from parts.com. I could check on the rest of it tomorrow.
