clk 500 problems
Rating: Thread Rating: 2 votes, 5.00 average.
Old Feb 1, 2011 | 07:58 PM
dansclk's Avatar
clk 500
clk 500 problems
I just got a used 2004 clk 500 and about 3 days ago the car has been acting up. I haven't driven the car hard or anything and i don't have a warranty.. what's happening is when i pull out and hit the gas im fine but once i hit 3rd gear it like vibrates my car and feels like its losing power. or like im driving on those rumble things on the shoulder of the road. when i let off the gas and push back down it seems fine. unless im on a hill then it will start doing it again. tranny isnt slipping or anything. no malfunctions on the display. im at a complete loss. i tried resetting the tranny as well with no luck. any help or guidance would be great. thatnks
-Dan
Old Feb 1, 2011 | 08:13 PM
M-bENZ's Avatar
Corrolla
Clean ur Maf sensors with CRC cleaner first ... If it still there check the CPS . Hope that helps .
Old Feb 1, 2011 | 08:19 PM
dansclk's Avatar
clk 500
Sorry I don't know much about cars yet. what is crc cleaner? and what is cps and how would I check it? my gf's dad is a mechanic so if i can have him do this and avoid the dealer then ill do that.
Old Feb 1, 2011 | 08:29 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
If you don't have the confidence in DIY then you should take it to your gf's dad. I would feel safer if he had worked on MBs before.
Old Feb 1, 2011 | 08:32 PM
dansclk's Avatar
clk 500
I plan on it. but being that its my car im just curious as to what things are and why i would be using it and what it does.
Old Feb 1, 2011 | 08:33 PM
M-bENZ's Avatar
Corrolla
You can get the CRC cleaner at autozone or pepboy . CPS = crank position sensor .
Old Feb 1, 2011 | 08:41 PM
dansclk's Avatar
clk 500
ok thanks ill have it checked into and let u guys know how it goes. it doesn't sound like a tranny issue does it? someone mentioned checking alternator voltages could that b possible?
Old Feb 1, 2011 | 08:47 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I would start with the basics that Andy mentioned. Those are common W209 problems.
Old Feb 1, 2011 | 10:00 PM
bbrain's Avatar
1999 Civic Hatchback, 2002 c240, 2003 CLK 500
+1
Old Feb 15, 2011 | 06:45 AM
dansclk's Avatar
clk 500
OK so last week i had had the car checked out at a local shop. a squirrel or something built a nest in my airbox.. but that didnt solve the problem.. brought it back and i was told try injector cleaner. they seem to think its not the tranny. i ran seafoam in it and didnt get anything results. so i took it the the benz dealer and they found that where the hire harness goes into the tranny the seal or whatever was bad. got that taken car of and i still am having the same problem. still no check engine light or malfuctions. and I dont think the cps or the maf sensors were checked like i requested..
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
