Alignment Spec Sheet Help
Old Mar 10, 2011 | 06:09 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
While the car was in the shop I had a 4 wheel alignment done. I have the spec sheet here, but I'm kind of lost reading it. I would appreciate if anybody out there can help me making sense of this. Thanks
Old Mar 10, 2011 | 06:34 PM
kevblah's Avatar
E90 M3
I think it says everything is fine.
Old Mar 10, 2011 | 06:43 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
lol
Old Mar 10, 2011 | 06:50 PM
Clkboi's Avatar
CLS550 4Matic
Seriously so many numbers and codes.
Didnt the shop explain all those to you?
Old Mar 10, 2011 | 07:53 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I didn't even see the sheet until I got in the car. It was lying on the passenger seat.
Old Mar 11, 2011 | 01:18 AM
Fai+H777's Avatar
ML55 AMG
I bet you its a stealership ploy to make you worry about all the digits so that you'll have to come in to pay for a "Mercedes dealership psychotherapy" session...
Old Mar 11, 2011 | 06:37 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Lol, I havent visited the dealer in a long time. This was my Indie shop.
Old Mar 11, 2011 | 08:59 AM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Maybe Ghostrider will chime in here with an explanation. In talking with him, he seems pretty sharp with the figures.
Old Mar 11, 2011 | 09:04 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Good idea. I will PM him now.
Old Mar 11, 2011 | 10:06 AM
Ghostrider@P1 Performance's Avatar
CLK430
That's crazy!! But everything looks fine. I can't believe they wouldn't just give you a normal printout. Did they say whether or not it was in spec?
Old Mar 11, 2011 | 10:19 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
They said everything was good. I was just curious about all the different readings. I usually see these spec sheets much more concise detailing each corner.
Old Mar 11, 2011 | 10:49 AM
CLK430
It looks like they took different measurments at different suspension compression points.
Old Mar 11, 2011 | 11:02 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Makes sense. Thanks
Old Mar 11, 2011 | 11:15 AM
user 76208202's Avatar
CLK550
What specs did you ask for? What specs should i ask for after i install the rear camber kit?
Old Mar 11, 2011 | 11:27 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
lol, I didn't even know the alignment was going to be done. I recently installed Ghostrider's anti-squeak links and haven't been back to the shop since so I guess the alignment was needed.
Old Mar 11, 2011 | 01:31 PM
Mka77's Avatar
I'm going to have the shop Ghostrider uses do my alignment, and if the price is right just install the camber kit as well. Melvin, any idea what they might charge to do it?
Stopped by up there yesterday around 2 and they were closed. Huh
Old Mar 11, 2011 | 01:36 PM
CLK430
They may have been at lunch, since they are open til 7. They will work with you but it usually pays an hour per side, I could give them some pointers to make it easier.
Old Mar 11, 2011 | 01:40 PM
Mka77's Avatar
That would great. Let me know. I'm ready anytime they can do it. Thanks Melvin
Old Mar 11, 2011 | 04:29 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
It looks like [those are] different measurments at different suspension compression points.
+1
Those are MB’s preferred alignment specifications, not your actual settings/readings.
Because changing front and rear ride substantially affects camber, caster and toe,
MB lists different angles to account for the changes that invariably occur as the suspension cycles through its travel.
Note the factory specifications are not necessarily ideal for fully exploiting available grip and/or maximizing potential tire life.
Savvy enthusiasts will often alter them to better suit their specific purposes.
Generic example of readout:
image credit 91RS
Old Mar 11, 2011 | 04:33 PM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Good post.
Old Mar 11, 2011 | 04:42 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Good info! Thanks.
Old Mar 11, 2011 | 04:58 PM
CLK430
Originally Posted by splinter
+1
image credit 91RS
Awesome explanation!! I was looking for one of my sheets to display.
