Quote:
I got my set from Eric at Supreme Power.Originally Posted by guku0701
where did you get your set from?i thought this was a good price since im planning to use the same tires im using now.
eric@supremepower.com - email him and mention Richie with the CLK55 Mandrus Rotec from Canada.
thanks will do Originally Posted by AvocentAMG
I got my set from Eric at Supreme Power.eric@supremepower.com - email him and mention Richie with the CLK55 Mandrus Rotec from Canada.
Hi guys
i found this thread while googling for wheels fitment for my c209
i am thinking to get a second hand ADV10 but they are 20" staggered at 9.5" and 10.5" ET 50, with tyres 245/30 & 285/25, they are off a C212
would appreciate your two cents
cheers
cheers
dont think they will fit bro
guys, any idea if 18x9 et.31 and rear 18x10.5 et. 34 will fit a clk550 without modification?
thanks
thanks
Wtb 2 19x7.5 40 bolt hole inners. Paypal ready plz text 6 four 7 2 zero six 3 one 4 four.
Mike
Also fs:
19x 1.5 lips x2
19x2.5 lips x2
19x 6.5 inners x4
HrE 40 bolt hole perfect shape lips were sprayed black by previous owner. No bends dings or rash.
Mike
Also fs:
19x 1.5 lips x2
19x2.5 lips x2
19x 6.5 inners x4
Ok, I'm confused and need some help with my 2003 CLK500. I have the AMG 17" staggered rims with the 225's in front and the 245's in back, and I like the look. One of the fronts is bent and cannot be fixed, so I am thinking it might be time to go to 18's. Can anyone tell me if these 18's will fit my stock CLK500 and look better?
This is a staggered set of 18 inch Mercedes-Benz AMG rims:
FRONT 7 1/2 Jx18 H2ET7 A1711041602
REAR 8 1/2 Jx18 H2ET30 A1714011702
I'm thinking the front should be 37, right? So maybe it's a typo? I cannot imagine a 7 offset for any MBZ wheels.
Thanks for your help!
ExploreJunior Member
Quote:
Mike
Also fs:
19x 1.5 lips x2
19x2.5 lips x2
19x 6.5 inners x4
I texted you, I got what u needOriginally Posted by emm3speed
Wtb 2 19x7.5 40 bolt hole inners. Paypal ready plz text 6 four 7 2 zero six 3 one 4 four.Mike
Also fs:
19x 1.5 lips x2
19x2.5 lips x2
19x 6.5 inners x4
Hello everyone,
I have been searching all over the forum and other websites but I can not find a proper answer. My question is regarding my tires size since I have 18x8.0 et35 rims all squared with 225/40/18. I want to upgrade it to 225/40/18 front and 255/35/18 rear. Would that be possible for 18x8.0 to adopt 255/35 without rubbing or being squuezed on the rims. Or should i put 245/40/18 rear and put 10 mm spacers. Please I'm looking for a quick response. Sorry I dont have a pic of my car!!!
I am looking to change my OEM stock 17" wheels on my 05 CLK 500. I have stock suspension, stock everything. I found these AMG Replicas: http://www.oewheelsllc.com/Wheels_3/...4#.UiPqLdJwr9q Those are not staggered but these are: http://www.usarim.com/wheels-rims-fi...ms-p-1230.html
Which one will be better for my car?I don't want to have any problems. It's kind of like Sweet jones's rims but 18" and no lowering of any kind. Should I lower it? Will there be any rubbing, hassles, etc? Thanks
Folks, I'm looking for a set of winter tires & wheels for a 07 CLK 550 and would like to get your thoughts if a 17x8.0 et35 rims with 245/45/17 tires will fit on both front and rear. I currently have 235/40/18 (front) and 255/35/18 (rear) on an OEM rims with H&R spacers. I m pretty new to this and would appreciate your help. Thanks!
Quote:
Yes that will work. You won't need spacers either.
Thanks AvocentAMG! I would assumed you have tried this size in your car? Any noticeable difference in the handling? Btw NICE set up you have there
Hi guys, I am thinking of to have some flush setup, will these has issues?
F: 18x8.5 ET20
R: 18x9.5 ET15
Plan to put on 215\225 for the front and 235 tires for the rear
Another not too aggressive setup
F: 18x9 ET30
R: 18x9 ET20
Any comments? Thanks.
F: 18x8.5 ET20
R: 18x9.5 ET15
F: 18x9 ET30
R: 18x9 ET20
Quote:
No I haven't, but it's very close to stock size. Originally Posted by llacer88
Thanks AvocentAMG! I would assumed you have tried this size in your car? Any noticeable difference in the handling? Btw NICE set up you have there Thanks
Quote:
F: 18x8.5 ET20
R: 18x9.5 ET15
F: 18x9 ET30
R: 18x9 ET20
Originally Posted by boyg
Hi guys, I am thinking of to have some flush setup, will these has issues?F: 18x8.5 ET20
R: 18x9.5 ET15
F: 18x9 ET30
R: 18x9 ET20
F: 18x8.5 ET20
R: 18x9.5 ET15
This could work with the tire size you've chosen.
I ran R: 18x9.5 ET15 with 265/35 in the rear and rubbed like crazy. 235 will give you a nice stretch.
The fronts you'll have to go 215, if not lower. ET20 is really low for the front.
Quote:
F: 18x8.5 ET20
R: 18x9.5 ET15
Thanks mate, how about this?Originally Posted by AvocentAMG
No I haven't, but it's very close to stock size. Thanks
F: 18x8.5 ET20
R: 18x9.5 ET15
F: 18x9 ET30
R: 18x9 ET20
235 in the front would be too much?
Quote:
F: 18x9 ET30
R: 18x9 ET20
Thanks mate, how about this?F: 18x9 ET30
R: 18x9 ET20
That's a little wide for the front.
I'd go with 225 or even 215
Trial setup with the offset above, I know it looks like a jeep now, drop is pending after wheels setup all goodOriginally Posted by AvocentAMG
That's a little wide for the front.I'd go with 225 or even 215
ADV10, picked 18x9J on all corners for its deep concave.
F - 10mm spacers > ET30
R - 20mm spacers > ET20
235 40 18 at the front now, inner clearence is scary tight, but they are clear, will swap to 225 soon anyway.
Currently considering an almost-new set of Avant Garde M510 19" wheels for my CLK550 Cab with stock suspension. Rears are 9.5", fronts 8.5", and all 40ET. Would run 255's in rear and 225's in front. I currently have 15mm rear (rolled fenders) and 10mm H&R spacers on stock 18" AMG wheels. Will the M510 19's work with 40ET work? Will I need my current spacers on the M510 19's?
BTW, what are the stock specs for 18" wheels on my CLK550 Cab.....width, backspacing and offset?
thanks
thanks
40 et with 15mm rear and 10mm front would work.
Quote:
I had the rear fenders rolled to allow for 15mm spacers on the stock 18" wheels.......I really like their flush look. Will the 19's (9.5/40ET) with 15mm spacers on the rear have the same flush look? No rubbing expected??Originally Posted by omega48er
Quote:
I put 18x9J ET40 with 20mm spacer in the rear and it still have plently of room, I think I can go 5mm more to flush it, but of course it still depends on what tires you are using, myself put 235 on 9J.Originally Posted by Dandaco
Quote:
I'll be putting on 255's in the rear. I'm not knowledgable enough on the subject to know if the 19/9.5 wheels with 40ET + 15mm spacers amount to the same face fit as the stock wheels with 15mm. Anyone?Originally Posted by boyg
So i was searchibg my local CL when i stumpled upon 19 chrome madrus manhilliem wheels at a pretty decent price. I would like to know if there is anyway i could get these to fit. If so, how?
Heres the specs he gave me...
5x112
Rear 19 x 10 1/2 backspacing 7 3/8" 35mm offset
Front 19 x 9 1/2 34mm offset backspacing 6 1/2
Thanks for the help!
5x112
